Hi. Thanks for answer. Below part is related, but not sure what to do with it:
Full log from today is below. Please, don’t pay attention on lot of errors (PS4, yeelight), devices were turned off from power and they are working properely with HA when they are turned on. I am interested here for sun component.
2020-02-19 01:37:48 ERROR (SyncWorker_4) [homeassistant.components.yeelight] Unable to update device 192.168.0.14, bulb: A socket error occurred when sending the command.
2020-02-19 06:17:27 ERROR (MainThread) [homeassistant.components.ps4.media_player] Could not find data in region: United States for PS ID: CUSA02012
2020-02-19 06:17:28 ERROR (SyncWorker_3) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 06:17:28 ERROR (SyncWorker_0) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 06:17:28 ERROR (SyncWorker_3) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 06:17:28 ERROR (SyncWorker_0) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 06:18:43 ERROR (SyncWorker_1) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 06:18:44 ERROR (SyncWorker_1) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 06:18:48 ERROR (SyncWorker_6) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 06:18:49 ERROR (SyncWorker_6) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 07:33:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.playstation_4 is taking over 10 seconds
2020-02-19 07:33:35 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 07:33:46 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 07:33:57 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 07:34:08 WARNING (MainThread) [homeassistant.components.ps4.media_player] PS4 could not be reached
2020-02-19 09:12:57 ERROR (SyncWorker_4) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 09:12:58 ERROR (SyncWorker_4) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 09:13:21 ERROR (MainThread) [homeassistant.components.ps4.media_player] Could not find data in region: United States for PS ID: CUSA00556
2020-02-19 09:13:22 ERROR (SyncWorker_0) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 09:13:23 ERROR (SyncWorker_0) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 11:09:40 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-19 11:09:44 ERROR (MainThread) [homeassistant.setup] Error during setup of component sun
File “/usr/lib/python3.8/site-packages/homeassistant/setup.py”, line 169, in _async_setup_component
result = await component.async_setup( # type: ignore
File “/usr/lib/python3.8/site-packages/homeassistant/components/sun/init.py”, line 82, in async_setup
Sun(hass)
File “/usr/lib/python3.8/site-packages/homeassistant/components/sun/init.py”, line 106, in init
update_location(None)
File “/usr/lib/python3.8/site-packages/homeassistant/components/sun/init.py”, line 103, in update_location
self.location = get_astral_location(self.hass)
File “/usr/lib/python3.8/site-packages/homeassistant/helpers/sun.py”, line 22, in get_astral_location
from astral import Location
ImportError: cannot import name ‘Location’ from ‘astral’ (/usr/lib/python3.8/site-packages/astral/init.py)
2020-02-19 11:09:46 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: sun
2020-02-19 11:09:46 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-02-19 11:10:00 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry UPnP/IGD for upnp
File “/var/lib/hass/deps/lib/python3.8/site-packages/async_upnp_client/aiohttp.py”, line 103, in async_do_http_request
async with self._session.request(method, url, headers=headers, data=body) as response:
File “/usr/lib/python3.8/site-packages/aiohttp/client.py”, line 1012, in aenter
self._resp = await self._coro
File “/usr/lib/python3.8/site-packages/aiohttp/client.py”, line 480, in _request
conn = await self._connector.connect(
File “/usr/lib/python3.8/site-packages/aiohttp/connector.py”, line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/lib/python3.8/site-packages/aiohttp/connector.py”, line 858, in _create_connection
_, proto = await self._create_direct_connection(
File “/usr/lib/python3.8/site-packages/aiohttp/connector.py”, line 980, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File “/usr/lib/python3.8/site-packages/aiohttp/connector.py”, line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File “/usr/lib/python3.8/asyncio/base_events.py”, line 1006, in create_connection
sock = await self._connect_sock(
File “/usr/lib/python3.8/asyncio/base_events.py”, line 920, in _connect_sock
await self.sock_connect(sock, address)
File “/usr/lib/python3.8/asyncio/selector_events.py”, line 494, in sock_connect
return await fut
asyncio.exceptions.CancelledError
File “/usr/lib/python3.8/site-packages/homeassistant/config_entries.py”, line 214, in async_setup
result = await component.async_setup_entry( # type: ignore
File “/usr/lib/python3.8/site-packages/homeassistant/components/upnp/init.py”, line 148, in async_setup_entry
device = await async_discover_and_construct(hass, config_entry.data.get(“udn”))
File “/usr/lib/python3.8/site-packages/homeassistant/components/upnp/init.py”, line 117, in async_discover_and_construct
return await Device.async_create_device(hass, ssdp_description)
File “/usr/lib/python3.8/site-packages/homeassistant/components/upnp/device.py”, line 57, in async_create_device
upnp_device = await factory.async_create_device(ssdp_description)
File “/var/lib/hass/deps/lib/python3.8/site-packages/async_upnp_client/client_factory.py”, line 52, in async_create_device
root = await self._async_get_url_xml(description_url)
File “/var/lib/hass/deps/lib/python3.8/site-packages/async_upnp_client/client_factory.py”, line 290, in _async_get_url_xml
await self.requester.async_http_request(‘GET’, url)
File “/var/lib/hass/deps/lib/python3.8/site-packages/async_upnp_client/client.py”, line 66, in async_http_request
await self.async_do_http_request(method,
File “/var/lib/hass/deps/lib/python3.8/site-packages/async_upnp_client/aiohttp.py”, line 113, in async_do_http_request
resp_body = None
File “/usr/lib/python3.8/site-packages/async_timeout/init.py”, line 55, in aexit
self._do_exit(exc_type)
File “/usr/lib/python3.8/site-packages/async_timeout/init.py”, line 92, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
2020-02-19 11:10:00 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/lib/python3.8/site-packages/homeassistant/data_entry_flow.py”, line 109, in async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File “/usr/lib/python3.8/site-packages/homeassistant/data_entry_flow.py”, line 172, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File “/usr/lib/python3.8/site-packages/homeassistant/components/homekit_controller/config_flow.py”, line 234, in async_step_zeroconf
existing = find_existing_host(self.hass, hkid)
File “/usr/lib/python3.8/site-packages/homeassistant/components/homekit_controller/config_flow.py”, line 61, in find_existing_host
if entry.data[“AccessoryPairingID”] == serial:
KeyError: ‘AccessoryPairingID’
2020-02-19 11:10:22 ERROR (MainThread) [homeassistant.components.ps4.media_player] Could not find data in region: United States for PS ID: CUSA00556
2020-02-19 11:31:48 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.playstation_4 is taking over 10 seconds
2020-02-19 11:31:49 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 11:31:49 ERROR (SyncWorker_0) [homeassistant.components.yeelight] Unable to update device 192.168.0.14, bulb: Bulb closed the connection.
2020-02-19 11:32:00 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 11:32:11 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 11:32:22 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 11:32:33 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 11:32:43 WARNING (MainThread) [homeassistant.components.media_player] Updating ps4 media_player took longer than the scheduled update interval 0:00:10
2020-02-19 11:32:54 WARNING (MainThread) [homeassistant.components.ps4.media_player] PS4 could not be reached
2020-02-19 13:53:48 ERROR (SyncWorker_7) [homeassistant.components.yeelight] Unable to update device 192.168.0.14, bulb: Bulb closed the connection.
2020-02-19 14:27:16 ERROR (SyncWorker_1) [homeassistant.components.pushbullet.notify] No such target: device/telephone
2020-02-19 14:27:17 ERROR (SyncWorker_1) [homeassistant.components.pushbullet.notify] No such target: channel/my_home
2020-02-19 14:27:38 ERROR (MainThread) [homeassistant.components.ps4.media_player] Could not find data in region: United States for PS ID: CUSA00556
2020-02-19 15:27:46 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: not a directory @ data[‘whitelist_external_dirs’][0]. Got ‘/usr/var/dumping-ground’. (See /var/lib/hass/configuration.yaml, line 14).
2020-02-19 15:27:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/lib/python3.8/site-packages/homeassistant/core.py”, line 1201, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service persistent_notification/create
2020-02-19 15:28:25 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-19 15:28:29 ERROR (MainThread) [homeassistant.setup] Error during setup of component sun
Sun(hass)
2020-02-19 15:28:30 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: sun
2020-02-19 15:28:30 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-02-19 15:28:45 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry UPnP/IGD for upnp
return await fut
resp_body = None
2020-02-19 15:28:45 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-02-19 15:29:03 ERROR (MainThread) [homeassistant.components.ps4.media_player] Could not find data in region: United States for PS ID: CUSA00556
Many thanks in advance.
