After the update of HA with the 2022.3 release, I’ve got some weird errors in the home-assistant.log file:
2022-03-10 15:18:15 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading configuration flow for integration wiz: cannot import name 'PIR_SOURCE' from 'pywizlight.bulb' (/usr/local/lib/python3.9/site-packages/pywizlight/bulb.py)
2022-03-10 15:18:15 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 743, in async_create_flow
integration.get_platform("config_flow")
File "/usr/src/homeassistant/homeassistant/loader.py", line 572, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 589, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 972, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "/usr/src/homeassistant/homeassistant/components/wiz/__init__.py", line 8, in <module>
from pywizlight.bulb import PIR_SOURCE
ImportError: cannot import name 'PIR_SOURCE' from 'pywizlight.bulb' (/usr/local/lib/python3.9/site-packages/pywizlight/bulb.py)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 203, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 221, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 750, in async_create_flow
raise data_entry_flow.UnknownHandler
homeassistant.data_entry_flow.UnknownHandler
2022-03-10 15:18:16 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
It seems related to the Wiz integration which is installed in my configuration.
Wiz lights seems to work normally either.
Any help or clues will be appreciated.
