As from yesterday, when I restarted home-assistant, I cannot open Lovelace any more, got this:
System: Archlinux
HA: Home Assistant Core 2021.9.7-1 installed directly on OS from Arch community repo
I think it is something related with HA web API, but after lot of googling, I found lot of topics without solution.
On top of this, I think that HA is working, but the problem is that I cannot open the frontend. E.g. I have some automation that turning off lights and other devices, when all person trackers are away (not_home). Before half hour, I drove the kids to school and wife to work, came back to home (working from home ) and saw that all lights where physical wall switch is turned on, were actually turned off, so this means that automation is working. Also, systemctl status home-assistant
is giving me Active: active (running)
This is from log and I will be glad to provide any additional info required. Thanks in advance.
2021-10-12 08:33:45 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /var/lib/hass/configuration.yaml contains duplicate key “service”. Check lines 291 and 294
2021-10-12 08:33:45 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /var/lib/hass/configuration.yaml contains duplicate key “data”. Check lines 292 and 295
2021-10-12 08:33:45 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration simpleicons which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-12 08:33:45 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-12 08:33:45 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-12 08:33:45 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration fontawesome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-12 08:33:55 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn’t connect to 192.168.0.6:5555. TcpTimeoutException: Connecting to 192.168.0.6:5555 timed out (1.0 seconds)
2021-10-12 08:33:55 WARNING (MainThread) [homeassistant.components.androidtv.media_player] Could not connect to Orion TV at 192.168.0.6:5555 using Python ADB implementation with adbkey=‘/var/lib/hass/.storage/androidtv_adbkey’
2021-10-12 08:33:55 WARNING (MainThread) [homeassistant.components.media_player] Platform androidtv not ready yet: None; Retrying in background in 30 seconds
2021-10-12 08:33:55 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/lib/python3.9/site-packages/aiohttp/web_protocol.py”, line 422, in _handle_request
resp = await self._request_handler(request)
File “/usr/lib/python3.9/site-packages/aiohttp/web_app.py”, line 499, in _handle
resp = await handler(request)
File “/usr/lib/python3.9/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/security_filter.py”, line 60, in security_filter_middleware
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/forwarded.py”, line 89, in forwarded_middleware
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/request_context.py”, line 24, in request_context_middleware
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/ban.py”, line 78, in ban_middleware
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/auth.py”, line 144, in auth_middleware
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/view.py”, line 135, in handle
result = await result
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/ban.py”, line 93, in handle_req
resp = await func(view, request, *args, **kwargs)
File “/usr/lib/python3.9/site-packages/homeassistant/components/auth/init.py”, line 259, in post
return await self._async_handle_refresh_token(hass, data, request.remote)
File “/usr/lib/python3.9/site-packages/homeassistant/components/auth/init.py”, line 364, in _async_handle_refresh_token
access_token = hass.auth.async_create_access_token(
File “/usr/lib/python3.9/site-packages/homeassistant/auth/init.py”, line 461, in async_create_access_token
return jwt.encode(
AttributeError: ‘str’ object has no attribute ‘decode’
2021-10-12 08:33:55 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140044575841536] Unexpected error inside websocket API
File “/usr/lib/python3.9/site-packages/homeassistant/components/websocket_api/http.py”, line 192, in async_handle
connection = await auth.async_handle(msg_data)
File “/usr/lib/python3.9/site-packages/homeassistant/components/websocket_api/auth.py”, line 82, in async_handle
refresh_token = await self._hass.auth.async_validate_access_token(
File “/usr/lib/python3.9/site-packages/homeassistant/auth/init.py”, line 510, in async_validate_access_token
unverif_claims = jwt.decode(token, verify=False)
TypeError: decode() got an unexpected keyword argument ‘verify’
2021-10-12 08:34:04 WARNING (MainThread) [homeassistant.components.light] Setup of light platform flux_led is taking over 10 seconds.
2021-10-12 08:34:05 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn’t connect to 192.168.0.6:5555. TcpTimeoutException: Connecting to 192.168.0.6:5555 timed out (1.0 seconds)
2021-10-12 08:34:05 WARNING (MainThread) [homeassistant.components.androidtv.media_player] Could not connect to Orion TV at 192.168.0.6:5555 using Python ADB implementation with adbkey=‘/var/lib/hass/.storage/androidtv_adbkey’
2021-10-12 08:34:14 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/lib/python3.9/site-packages/homeassistant/components/http/forwarded.py”, line 211, in forwarded_middleware
return jwt.encode(
2021-10-12 08:34:15 ERROR (MainThread) [aiohttp.server] Error handling request
return jwt.encode(
return jwt.encode(
2021-10-12 08:34:15 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140044234523312] Unexpected error inside websocket API
2021-10-12 08:34:27 WARNING (MainThread) [homeassistant.components.ps4.media_player] PS4 could not be reached
2021-10-12 08:35:06 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn’t connect to 192.168.0.6:5555. TcpTimeoutException: Connecting to 192.168.0.6:5555 timed out (1.0 seconds)
2021-10-12 08:35:06 WARNING (MainThread) [homeassistant.components.androidtv.media_player] Could not connect to Orion TV at 192.168.0.6:5555 using Python ADB implementation with adbkey=‘/var/lib/hass/.storage/androidtv_adbkey’
2021-10-12 08:36:37 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn’t connect to 192.168.0.6:5555. TcpTimeoutException: Connecting to 192.168.0.6:5555 timed out (1.0 seconds)
2021-10-12 08:36:37 WARNING (MainThread) [homeassistant.components.androidtv.media_player] Could not connect to Orion TV at 192.168.0.6:5555 using Python ADB implementation with adbkey=‘/var/lib/hass/.storage/androidtv_adbkey’
