Hi Folks,
I’m following the directions on the Local add-on testing page using a Mac running OS X 11.3.1.
My error log after rebuilding my container and running the “Start Home Assistant” task is below.
I attempted debugging by dropping to the Docker CLI and trying to create the hassio network manually, but that didn’t work.
$ docker network create \
--driver=bridge \
--subnet=172.30.32.0/23 \
--ip-range=172.30.33.0/24 \
--gateway=172.30.32.0 \
hassio
Error Log
Start Test-Env
update-alternatives: using /usr/sbin/iptables-legacy to provide /usr/sbin/iptables (iptables) in manual mode
update-alternatives: error: alternative /usr/sbin/iptables-legacy for ip6tables not registered; not setting
Fails adjust ip6tables
Starting docker.
Waiting for docker to initialize...
Docker was initialized
Total reclaimed space: 0B
Cleaning up stopped containers...
Container name cannot be empty
Startup dbus
unix:path=/var/run/dbus/system_bus_socket,guid=72b32998241def6c0394af8f6094deae
Startup udev
Starting version 241
Unable to find image 'homeassistant/amd64-hassio-supervisor:2021.05.dev0301' locally
2021.05.dev0301: Pulling from homeassistant/amd64-hassio-supervisor
540db60ca938: Pull complete
5410ef35c7ab: Pull complete
eebec9a33904: Pull complete
2f698171abbe: Pull complete
d5ecbe636a25: Pull complete
564b4c8fcf87: Pull complete
95371a052e4c: Pull complete
bc7dadd33921: Pull complete
d87227e7d06d: Pull complete
ccabd5035be8: Pull complete
e35cfd4460f3: Pull complete
dfb684fd2045: Pull complete
467af05c8f42: Pull complete
Digest: sha256:d69270bbdf832ea147af2140fab9b28999710621907d6e1b9e56d95c26dcc713
Status: Downloaded newer image for homeassistant/amd64-hassio-supervisor:2021.05.dev0301
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[06:31:57] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[06:31:57] INFO: Starting local supervisor watchdog...
21-05-07 06:31:57 INFO (MainThread) [__main__] Initializing Supervisor setup
21-05-07 06:31:57 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
File "/usr/local/lib/python3.8/site-packages/docker/api/client.py", line 268, in _raise_for_status
response.raise_for_status()
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 943, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http+docker://localhost/v1.41/networks/create
File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/src/supervisor/supervisor/__main__.py", line 41, in <module>
coresys = loop.run_until_complete(bootstrap.initialize_coresys())
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 616, in run_until_complete
return future.result()
File "/usr/src/supervisor/supervisor/bootstrap.py", line 60, in initialize_coresys
coresys = CoreSys()
File "/usr/src/supervisor/supervisor/coresys.py", line 68, in __init__
self._docker: DockerAPI = DockerAPI()
File "/usr/src/supervisor/supervisor/docker/__init__.py", line 96, in __init__
self.network: DockerNetwork = DockerNetwork(self.docker)
File "/usr/src/supervisor/supervisor/docker/network.py", line 25, in __init__
self.network: docker.models.networks.Network = self._get_network()
File "/usr/src/supervisor/supervisor/docker/network.py", line 91, in _get_network
return self.docker.networks.create(
File "/usr/local/lib/python3.8/site-packages/docker/models/networks.py", line 156, in create
resp = self.client.api.create_network(name, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/docker/api/network.py", line 153, in create_network
return self._result(res, json=True)
File "/usr/local/lib/python3.8/site-packages/docker/api/client.py", line 274, in _result
self._raise_for_status(response)
File "/usr/local/lib/python3.8/site-packages/docker/api/client.py", line 270, in _raise_for_status
raise create_api_error_from_http_exception(e)
File "/usr/local/lib/python3.8/site-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 500 Server Error for http+docker://localhost/v1.41/networks/create: Internal Server Error ("Failed to Setup IP tables: Unable to enable SKIP DNAT rule: (iptables failed: iptables --wait -t nat -I DOCKER -i hassio -j RETURN: iptables: No chain/target/match by that name.
(exit status 1))")
21-05-07 06:31:58 ERROR (MainThread) [asyncio] Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0x7f75e496bc70>
client_session: <aiohttp.client.ClientSession object at 0x7f75e496bee0>
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Stopping in container docker...
Your host might have been left with unreleased resources
Press any key to close the terminal.
