Hello all! I have installed a fresh copy of Hassbian on my rPi 3 and am trying to use the Bluetooth LE Tracking component. I am running into an issue though and get the following error on boot:
Error setting up platform bluetooth_le_tracker
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 184, in async_setup_platform
disc_info)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/bluetooth_le_tracker.py”, line 114, in setup_scanner
update_ble(dt_util.utcnow())
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/bluetooth_le_tracker.py”, line 96, in update_ble
devs = discover_ble_devices()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/bluetooth_le_tracker.py”, line 58, in discover_ble_devices
devs = adapter.scan()
File “/srv/homeassistant/lib/python3.5/site-packages/pygatt/backends/gatttool/gatttool.py”, line 312, in scan
scan = pexpect.spawn(cmd)
NameError: name ‘pexpect’ is not defined
I can see verify bluetooth is working using the following command:
sudo hcitool lescan
I tried installing the following to see if I could get the ‘pexpect’ library installed for python, but it had no effect:
sudo apt-get install python-pexpect
Any suggestions are appreciated, I feel as if I’ve exhausted my Google-fu on this one. Thank you!
