i plan to build a Thermometer for my Pool, wich has 4 DS18B20 Sensors,
one for AIR-Temp,
one for POOL-Water,
one for Solar-Heater,
one for Fire-Heater.
The DS18B20 are already working fine.
I want to use 2xMAX7219 Boards with 8x7Segment each for displaying the Temps.
How can i get the Temp-Values directly in ESPHome to the MAX7219?
Here the code i would use:
esphome:
platform: ESP8266
board: d1_mini
# Enable logging
#logger:
# Enable Home Assistant API
api:
password: "xxxxxxxx"
ota:
wifi:
networks:
- ssid: "Cxxxxxxx2"
- ssid: "Cxxxxxxx3"
manual_ip:
static_ip: 192.168.2.254
gateway: 192.168.2.1
subnet: 255.255.252.0
web_server:
port: 80
dallas:
- pin: GPIO05
update_interval: 30s
- platform: dallas
address: 0xdc000005948d4d28
- platform: dallas
address: 0xa800000593ec1d28
- platform: dallas
address: 0x6f0000059411c728
- platform: dallas
address: 0xf500000594396728
spi:
clk_pin: D0
mosi_pin: D1
display:
- platform: max7219
cs_pin: 04
num_chips: 2
lambda: |-
it.print("01234567ABCDEFGH");
so how can i display the 4 Temps on both displays?
It should look like this:
“_23.4_20.2”
“_27.9_75.2”
where the undescores are empty digits if temp <100.0 degree
(water wont be hotter than 99.9degree i hope )
but if -10.0 degree the minus sign should be shown.
