Hi everyone,
I am using a gas-meter based on ESPHome for more than a year now and recently (I think since 2024.7 get an error when I want to update the FW for the gas-meter:
Failed to perform the action update/install. Error compiling gas-meter-esp8266.yaml; Try again in ESPHome dashboard for more information.
Actually I don’t see what I can do in "System > Devices > ESPHome.
In the logs I see:
homeassistant.exceptions.HomeAssistantError: Error compiling gas-meter-esp8266.yaml; Try again in ESPHome dashboard for more information.
But also communication which looks ok on the current FW:
2024-08-12 14:50:44.598 DEBUG (MainThread) [aioesphomeapi.connection] gas-meter-esp8266 @ 192.168.68.82: Got message of type PingResponse:
2024-08-12 14:51:08.400 DEBUG (MainThread) [aioesphomeapi.connection] gas-meter-esp8266 @ 192.168.68.82: Got message of type SensorStateResponse: key:
I did not change anything on the .yaml config:
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "wurst"
ota:
password: "wurst"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Gas-Meter-Esp8266"
password: "wurst"
captive_portal:
globals:
- id: total_pulses
type: int
restore_value: false
initial_value: '0'
binary_sensor:
- platform: gpio
pin:
number: GPIO5
mode: INPUT_PULLUP
name: "Gas-Impulszähler (ESPHome)"
filters:
- delayed_on: 10ms
on_press:
then:
- lambda: id(total_pulses) += 1;
name: "Gasverbrauch [m³] (ESP)"
device_class: gas
unit_of_measurement: "m³"
state_class: "total_increasing"
icon: "mdi:fire"
accuracy_decimals: 2
lambda: |-
return id(total_pulses) * 0.01;
ESP_LOGD("Gaszähler TAG", "Pulse bisher: %d", id(total_pulses));
device_class: energy
unit_of_measurement: "kWh"
icon: "mdi:fire"
lambda: |-
return id(total_pulses) * 0.01 * 11.1;
Any help would be greatly appreciated.
