SOLVED: ESPHome in Sonoff - register relay as a light in HA?
I have a Sonoff Basic with ESPHome in it, that I’m using to control a light. In HA it’s registered as a switch, is there a way to have it register as a light instead?
My current config looks like this:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: SSID
  password: NotShown
api:
logger:
  baud_rate: 0
ota:
  password: "VerySecret"
time:
  - platform: homeassistant
text_sensor:
  - platform: version
    name: "Gang ESPHome Version"
  - platform: wifi_info
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    name: "Gang Sonoffc Button"
    on_press:
      - switch.toggle: relay
switch:
  - platform: gpio
    pin: GPIO12
status_led:
  pin:
    number: GPIO13
    inverted: yes
But it is a switch and not a light. Lights generally have colour and dim capabilities, switches are on and off.
You can change the icon of the identity so it is more recognizable if you want.
You can use the Light Switch in HA, but it’s one more entity.
Would this work ?
Thankyou all three for the input!
I think that would work, then I just need to figure out the output part, I can’t seem to get the syntax correct here :blush:
For now I’ve set it up with a lightswitch in HA, as per @VDRainer’s suggestion.
Let me google that for you
Thankyou for the googling expertise :smile:
So, the resulting config is:
substitutions:
  device_name: hallway
  # Higher value gives lower watt readout
  current_res: '0.00290'
  # Lower value gives lower voltage readout
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: SSID
  password: PASSWORD
api:
logger:
  baud_rate: 0
ota:
  password: "PASSWORD"
time:
text_sensor:
  - platform: version
    name: '${device_name} ESPHome Version'
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - light.toggle: lightbar
output:
  - platform: gpio
    pin: GPIO12
light:
  - platform: binary
    output: relay
status_led:
  pin:
    number: GPIO13
    inverted: yes
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    accuracy_decimals: 1
    filters:
      - multiply: 0.000011574
  - platform: wifi_signal
    name: '${device_name} WiFi Signal'
    accuracy_decimals: 0
I can see that in the example the !secret method is used, but if I try that, it will not compile, so is that not through ESPHome?
Secrets is a method to store passwords and alike in another file.
secrets.yaml
Yes, I’m using it already in my normal configs, but when I use it in ESPHome I get errors marked?
If you want to use secrets.yaml in ESPHome you have to create another secrets.yaml file next to your normal configuration files. If you are on hassio I don’t know if it is supported on the dash board directly or you have to put the file with another means like the configurator add on.
A symlink should work if you want to keep all your secrets in one place.
It doesn’t look like it, which is a bummer, I really want to keep it in Hass.io, trying to keep it manageble, at least somewhat, by others than just me.
@nickrout , ok, that would make it much cleaner, if just the editor supported it :thinking:
It’s coming https://github.com/esphome/esphome/pull/672
@glmnet Sounds great :slight_smile:
