I’m posting this here, hoping it might help someone one day. This post is just how I got things to work.
I wanted to create a tiny media player based on the M5Stack SPK kit. ESPHome Ready Made projects lists this device, but with a different controller than I had. I have an AtomS3 Lite.
The pinout on this Lite controller is different from all the examples I found online. As with all of these things, the solution is simple. Eventually.
The SPK kit neatly lists the pins associated with the required BCLK/DATA/LRCLK connections. These numbers are also printed on the PCB. Taking the AtomS3 Lite and lining the female pins up with the male SPK pins yields a mapping!
GPIO22 becomes GPIO5
GPIO21 becomes GPIO39
GPIO25 becomes GPIO38
Taking this mapping and the sample code from the Read Made projects yields this YAML:
substitutions:
friendly_name: M5 SPK AtomS3 Lite
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
platformio_options:
board_build.flash_mode: dio
project:
version: dev
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
i2s_audio:
- id: i2s_audio_bus
i2s_lrclk_pin: GPIO39
i2s_bclk_pin: GPIO05
media_player:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO38
mode: mono
binary_sensor:
- platform: gpio
pin:
number: GPIO41
inverted: true
on_click:
- media_player.toggle: media_out
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: 35
num_leds: 1
rmt_channel: 0
chipset: ws2812
name: AtomS3 lite Light
button:
- platform: safe_mode
name: Safe Mode Boot
- platform: factory_reset
I had to do something similar with the button GPIO.
The light was a bit more complex. But this issue in ESPHome had a solution that worked immediately.
I hope this helps someone!
