Solved: Esphomelib, homeassistant sensor, type error
Hello, I’m trying to use esphomelibs homeassistant sensor component with the new Native API. From looking at the esphomelib source code, it appears the only difference between the homeassistant sensor and text_sensor componnent is a parse_float function. I then assume if the state of an entity is numeric, I can use an entity from any hass domain (not just sensor.*) However I cannot get either component to work. NaN is displayed on my ESP display. Esphomelib yaml throws no errors. The input_slider is set up properly and works in homeassistant. Other components are presented properly from esphomelib to homeassistant.
In esphomelibyaml:
  • platform: homeassistant
    name: “Temperature Sensor From Home Assistant”
    entity_id: input_number.temp
display:
  • platform: …
    printf(“Temp: %.0f”, id(hass_temp).state);
HomeAssistant logs:
TypeError: <state input_number.temp=70.0; friendly_name=Temperature, mode=slider, initial=68.0, max=78.0, min=62.0, step=1.0 @ 2019-01-15T06
:56:08.316522-05:00> has type <class ‘homeassistant.core.State’>, but expected one of: (<class ‘bytes’>, <class ‘str’>) for field HomeAssist
antStateResponse.state
2019-01-15 06:56:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/srv/homeassistant/lib/python3.5/site-packages/google/protobuf/internal/python_message.py”, line 526, in init
setattr(self, field_name, field_value)
File “/srv/homeassistant/lib/python3.5/site-packages/google/protobuf/internal/python_message.py”, line 662, in field_setter
new_value = type_checker.CheckValue(new_value)
File “/srv/homeassistant/lib/python3.5/site-packages/google/protobuf/internal/type_checkers.py”, line 177, in CheckValue
raise TypeError(message)
TypeError: <state input_number.temp=68.0; friendly_name=Temperature, mode=slider, initial=68.0, max=78.0, min=62.0, step=1.0 @ 2019-01-15T06:56:14.747540-05:00> has type <class ‘homeassistant.core.State’>, but expected one of: (<class ‘bytes’>, <class ‘str’>)
File “/usr/lib/python3.5/asyncio/tasks.py”, line 239, in _step
result = coro.send(None)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/esphome/init.py”, line 215, in send_home_assistant_state
await cli.send_home_assistant_state(entity_id, new_state)
File “/srv/homeassistant/lib/python3.5/site-packages/aioesphomeapi/client.py”, line 748, in send_home_assistant_state
state=state,
File “/srv/homeassistant/lib/python3.5/site-packages/google/protobuf/internal/python_message.py”, line 528, in init
_ReraiseTypeErrorWithFieldName(message_descriptor.name, field_name)
File “/srv/homeassistant/lib/python3.5/site-packages/google/protobuf/internal/python_message.py”, line 448, in _ReraiseTypeErrorWithFieldName
six.reraise(type(exc), exc, sys.exc_info()[2])
File “/srv/homeassistant/lib/python3.5/site-packages/six.py”, line 692, in reraise
raise value.with_traceback(tb)
TypeError: <state input_number.temp=68.0; friendly_name=Temperature, mode=slider, initial=68.0, max=78.0, min=62.0, step=1.0 @ 2019-01-15T06:56:14.747540-05:00> has type <class ‘homeassistant.core.State’>, but expected one of: (<class ‘bytes’>, <class ‘str’>) for field HomeAssistantStateResponse.state
Please do everyone a favor and format your post correctly. It is really difficult to read and thereby even more difficult to find an error.
See https://github.com/home-assistant/home-assistant/pull/20048 - fixed in next HA patch release
Apologies, this is my first post. I will review the page you posted.
@cgtobi
