New user here with Home Assistant. Still playing around and trying to learn the ropes. I set everything up successfully with Home Assistant on a RPi4, and decided to change MicroSD cards and flashed that card. Went through the same install process and now I am prompted to create a new user. There is no option for logging in as an existing user. Same IP address, same device, just different SD card. Please help, I don’t want to create a new user at this point.
TiA.
I solved it myself.
Create the same user again. It works.
