I use HomeAssistant in a Docker container on my Raspberry Pi. I have set up a WireGurad VPN to my Hetzner server there (where I have the IP 10.0.2.2). An Nginx Proxy Manager is running on my Hetzner server, which forwards all requests from home.domain.tld (this is not my domain, but I don’t want to write it openly
) to 10.0.2.2:8123.
I want to allow access from outside only for my user (tuxilio) and not for all other users. I have activated “Local access only” for these users.
Then I added the IP of the proxy in my configuration.yaml:
http:
use_x_forwarded_for: true
ip_ban_enabled: true
login_attempts_threshold: 3
trusted_proxies:
- 10.0.2.1
However, if I go to home.domain.tld, I can still log in with this user.
I have also tested setting my external URL under /config/network, but this has no effect.
How can I change this?
