Hi
I’m trying to add new automation but it does not work. I need help, don’t know why it does not work.
Idea: Close a roller shutter (controlled by an Fibaro Roller Shutter 3 module) if the temperature is above 25 ° C (controlled with Philips Hue Outdoor Sensor).
Sensor and roller shutter both work well and are recognized on Has.
I tried with all different “mode”.
Am i doing something wrong ?
Thx
alias: Fermer volet
description: Fermer volet baie panoramique
- type: temperature
platform: device
device_id: cebf2cdd130a9cddd0472808b37fce9e
entity_id: sensor.hue_outdoor_motion_sensor_1_temperature
domain: sensor
above: 25
condition: []
- device_id: 918bb14675359b3cb04140f5cf5aa34d
domain: cover
entity_id: cover.volet_panoramique_current_value
type: set_position
position: 39
mode: single
Consider using numeric_state as trigger as shown here.
alias: Fermer volet
- platform: numeric_state
entity_id: 'sensor.hue_outdoor_motion_sensor_1_temperature'
above: '25'
# This can be added as a safeguard in case your HA reboot when the temperature crosses your threshold.
- platform: homeassistant
event: start
condition:
- condition: numeric_state
above: '25'
domain: cover
type: set_position
position: 39
mode: single
Please remember that for numeric_state
trigger to be triggered, it needs to be below your threshold and then go above your threshold.
Thx.
Currently, the philips detector indicates 39.68 ° C
It should therefore be triggered as soon as the temperature changes (example to indicate 40 ° C)?
And, Has automaticaly replaced
above: '25'
to: above: 25
It will not be triggered if the temperature is already above your threshold point which is 25 degree.
It needs to be, for example, 24 degree and then go up to more than 25 degree.
numeric_state
trigger-
Fires when the numeric value of an entity’s state (or attribute’s value if using the
attribute property) crosses a given threshold
Ok.
I’m trying with 40°C.
Also, you can also use service call cover.set_cover_position
for setting cover position.
- service: cover.set_cover_position
position: 39
What are the differences with my code?
It’s the same thing, no ?
Does the above YAML code works? If it works, then no need to change it.
For the moment it is not triggered…
It’s not easy to test aumation based on temparature.
You can try changing the value from-
Developer Tools → States (Tab) → Choose your sensor entity → Modify the state → Set State
Oh god… It works
Thx you so much !
I still have a lot to learn about Has.
