SOLVED - Frigate cameras not showing
Hey everyone,
I’m very new to Home Assistant, and I’m certainly am doing something silly, but I can’t point my finger to it.
I have installed on my HA the frigate add-on. I followed the wiki of Frigate and managed to create a configuration file. In Frigate, I can now see the 3 cameras I have set up there. It’s all showing and detection also works nicely.
I then installed the frigate integration, and that’s where the weird thing happens. I can only see one out of my 3 cameras inside HA. I checked the integration and it also shows only one out of the 3 cameras (the first one of the list). If I understand right how it works, if I have one, and have no error in the code, it should show all 3.
I keep checking the frigate.yaml (the wiki mentions frigate.yml, but I’m not sure whether I should follow that naming convention or not), but since the two next cameras is the same as the first one (I copied pasted and just renamed the entity and its stream), I’m not sure what I’m missing there.
If you have an idea, it would be very helpful to learn from my mistakes.
Here is the code of my frigate.yaml
 mqtt:
   host: mqtt://core-mosquitto
   user: mqtt-user
   password: supersecret
 cameras:
   camera_veranda: # <------ Name the camera
     ffmpeg:
       inputs:
         - path: rtsp://someadress/live/ch1 # <----- The stream you want to use for detection
           roles:
             - detect
             - rtmp
         - path: rtsp://someadress/live/ch0 # <----- The stream you want to use for detection
           roles:
             - record
     detect:
       enabled: True # <---- disable detection until you have a working camera feed
       width: 1280 # <---- update for your camera's resolution
       height: 720 # <---- update for your camera's resolution
     objects:
       track:
         - person
         - umbrella
     record:
       enabled: true
       retain:
         days: 10
       events:
         retain:
           default: 10
     snapshots:
       enabled: true
     motion:
       mask:
         - 877,0,1280,0,1280,36,878,37
   camera_salon: # <------ Name the camera
     ffmpeg:
       inputs:
           roles:
             - detect
             - rtmp
           roles:
             - record
     detect:
     objects:
       track:
         - person
         - umbrella
     record:
       enabled: true
       retain:
         days: 10
       events:
         retain:
           default: 10
     snapshots:
       enabled: true
     motion:
       mask:
   camera_hall: # <------ Name the camera
     ffmpeg:
       inputs:
           roles:
             - detect
             - rtmp
           roles:
             - record
     detect:
     objects:
       track:
         - person
         - umbrella
     record:
       enabled: true
       retain:
         days: 10
       events:
         retain:
           default: 10
     snapshots:
       enabled: true
     motion:
       mask:
Edit : For some reason, the situation just got solved. I simply restarted the whole HA and all the cameras are now available in HA. I just found a reference to the integration needing a restart after doing a zoning. Everything is now working perfectly.
