Here’s a simple example of the flow. Rather than have this same flow for five different rooms (areas). I’m trying to strip out the area value from the entity name to then turn on the appropriate light in that area.
"id": "7e8c20b971e9be1e",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "e2d1d51e1d85446d",
"type": "server-state-changed",
"z": "7e8c20b971e9be1e",
"name": "Bathroom Motion",
"server": "2244d24e336a3d2c",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "binary_sensor.bathroom_occupancy",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": true,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 460,
"y": 280,
"wires": [
"529b17eb6a6e860d"
"c2bf93062e4d1c77"
"id": "c2bf93062e4d1c77",
"type": "api-call-service",
"name": "Lights Off",
"version": 5,
"debugenabled": true,
"domain": "light",
"service": "turn_off",
"areaId": [],
"deviceId": [],
"entityId": [
"light.bathroom"
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 940,
"y": 280,
"wires": [
"id": "529b17eb6a6e860d",
"name": "Lights On",
"version": 5,
"domain": "light",
"service": "turn_on",
"areaId": [],
"deviceId": [],
"entityId": [
"light.bathroom"
"data": "",
"mergeContext": "",
"queue": "none",
"x": 940,
"y": 200,
"wires": [
"id": "2244d24e336a3d2c",
"type": "server",
"name": "Home Assistant",
"version": 2,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30
