[solved] Getting line graphs from values without unit
Home Assistant will plot line graphs only for sensors with unit_of_measurement set to non empty value. If you’d like to have a line graph and still not display any value after the number you just need to insert zero width space character.
In macOS just open Emoji & Symbols window and search for ‘space’, the character will be above B letter.
good solution with a bad description, here is the yaml code
    sensors:
      cop:
        friendly_name: "COP Mitsubishi"
        value_template: ""
        unit_of_measurement: "\u200B"
in this case I want to track the efficiency of my ACs
