I’m rewriting this whole post as I pin-pointed the issue is the image is failing to run for reasons I cannot figure out:
[email protected]:/home/pi/Downloads# docker logs homeassistant
standard_init_linux.go:228: exec user process caused: exec format error
That is an arch. type error.
[email protected]:/home/pi/Downloads# docker pull ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2022.4.7
2022.4.7: Pulling from home-assistant/raspberrypi3-64-homeassistant
Digest: sha256:8196827ca7fadfbd9e82f18fb9705bde9ee31a0d91a3ad0e580a14b95dec6251
Status: Image is up to date for ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2022.4.7
According to the image, it is an arm64 image:
[email protected]:~/Downloads $ docker inspect ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2022.4.7
"Id": "sha256:eab0c8d7adabd968fcad9958b31c17c28fa96001eeac10dd8a820ba0ee49ec46",
"RepoTags": [
"ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2022.4.7"
"Architecture": "arm64",
"Os": "linux",
"Size": 1278612041,
My CPU Info:
[email protected]enus-ha:~/Downloads $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 76.80
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
// [snip]
Hardware : BCM2835
Revision : a22082
Serial : 00000000fbdf1ae1
Model : Raspberry Pi 3 Model B Rev 1.2
I downgraded the Supervised installer to 1.0.2, and it installed arm7
based images, except for homeassistant:
[email protected]:~/Downloads $ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
ghcr.io/home-assistant/raspberrypi3-64-homeassistant 2022.4.7 eab0c8d7adab 8 days ago 1.28GB
homeassistant/armv7-hassio-supervisor 2022.04.0 ee2b73959439 4 weeks ago 274MB
homeassistant/armv7-hassio-supervisor latest ee2b73959439 4 weeks ago 274MB
ghcr.io/home-assistant/armv7-hassio-supervisor latest ee2b73959439 4 weeks ago 274MB
ghcr.io/home-assistant/armv7-hassio-multicast 2022.02.0 d491cf19fe51 2 months ago 58.8MB
ghcr.io/home-assistant/armv7-hassio-cli 2021.12.0 4701925805eb 4 months ago 66.9MB
ghcr.io/home-assistant/armv7-hassio-observer 2021.10.0 a880edc5261d 6 months ago 65.9MB
ghcr.io/home-assistant/armv7-hassio-audio 2021.07.0 e586552c248b 9 months ago 82MB
ghcr.io/home-assistant/armv7-hassio-dns 2021.06.0 fb6e6fa93a72 10 months ago 77.3MB
Everybody is running, except homeassistant:
[email protected]:~/Downloads $ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
459a7d210bc5 ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2022.4.7 "/init" 3 hours ago Exited (1) 3 hours ago homeassistant
d5bf31905872 ghcr.io/home-assistant/armv7-hassio-multicast:2022.02.0 "/init" 3 hours ago Up 3 hours hassio_multicast
1501005fb47d ghcr.io/home-assistant/armv7-hassio-audio:2021.07.0 "/init" 3 hours ago Up 3 hours hassio_audio
0a6778a3de37 ghcr.io/home-assistant/armv7-hassio-dns:2021.06.0 "/init" 3 hours ago Up 3 hours hassio_dns
a5087e017300 ghcr.io/home-assistant/armv7-hassio-cli:2021.12.0 "/init /bin/bash -c …" 3 hours ago Up 3 hours hassio_cli
1ba16444330b ghcr.io/home-assistant/armv7-hassio-observer:2021.10.0 "/init" 21 hours ago Up 3 hours 0.0.0.0:4357->80/tcp, :::4357->80/tcp hassio_observer
d6fe5fbf69aa ghcr.io/home-assistant/armv7-hassio-supervisor "/init" 21 hours ago Up 3 hours hassio_supervisor
Anybody have any ideas what’s going on?
