NOTHING i can do now. How could i get access to the system back and restore a snapshot?
Funny not aside: I still can access the system from my homehabit instance running on the Android tablet and can switch stuff etc …
Yeah. Thanks. Will do when back home. I tinkered a bit with some custom card yesterday, so there may be some dash or blank in the config where it doesn’t belong.
~ $ hassio homeassistant check
Processing... Done.
Error: Testing configuration at /config
INFO:homeassistant.util.package:Attempting install of pyShelly==0.1.10
Failed config
frontend:
- Invalid config for [frontend]: [javascript_Version] is an invalid option for [frontend]. Check: frontend->frontend->javascript_Version. (See /config/configuration.yaml, line 94).
and this was the offending entry (the javascript line):
Yes, sure. Luckily i could still access HA over smb. So this was quickly done.
Question now is, why this wasn’t working, as it was advised to add this to configuration.yaml for the custom card?!
This project moves quickly. Things get deprecated. If the “guide” you were following wasn’t updated to go along with the changes to the project, it’s going to break.
