Thank you for the suggestion. I unchecked “experimental features”, restarted HA, and unfortunately nothing else changed, still seeing the same screens. Any other ideas?
After you change the setting for experimental features, you must fully reload HACS. Restart Home Assistant and then, once Home Assistant has fully started, clear your browser cache.
I have this problem but my HACS integration settings doesn’t have that option, it only has “Enable AppDaemon apps discovery & tracking”. Is the menu not available in the newest versions?
I’m having the same issue as kevpatts. Experimental Features is not showing up to uncheck nor am I able to see HACS cards. Has anyone been able to fix this? I have the latest HACS version installed, cards just randomly disappeared.
Hi, Extreme noobie here, so please excuse my gaffs. I am trying to install an air purifier card in my HA setup. It is very confusing to me as to how to install what looks like javascript code into my HA instance. I notice there was a way to let my HACS frontend do the cryptic work for me. Trouble is…ther are no such options such as ‘frontend, explore repos, etc’ available in my HacS sidebar. it appears that my Google search is giving me old info, as I am already using HACS 2.05, so the uncheck experimental option is not available. I have rebooted my Ha green device, but it still doesn’t show the above window. Should I just give up and abandon this whole mess, or is there a clear way forward here? Thanks for any info…HA is very configurable, but only if one is an experienced programmer, at least that is my take.
It is better if you start a new thread, this one is not related to the same issue and it is already solved. In that way, more people can help you. Just open a new thread with some screenshots of your issue (it is normal that you don’t have the same as above in the screenshots because those are from an old HACS version).
