[Solved] Hass.io and Google Home executing scripts
I’ve setup my Hass.io to work with my Google Home device and I can turn on lights and stuff so it’s working fine, but how do I execute custom scripts. I created several script that execute perfectly through my Dashboard but when I try to execute them throught my Google Home it doesn’t do anything… Is there a special speech pattern when executing scripts ?
Any help is appreciated :slightly_smiling_face:
Thanks !
Update:
I’ve read this Google Home Scripts? but IFTTT is not something viable for me. How do you setup a shortcut in google how, can’t seem to find this.
Step one.
Confirm you can run the script with the voice command “turn on {script.name}”
Step two.
Smart home app -> more settings -> short cuts or routines. You can then set a different phrase and link that to turn on …
Look here.
Works perfectly, thank you for the link, I managed to activate my scripts with shortcuts.
