I’m trying to install hass.io on a raspberry pi 3 running a clean raspbian lite buster install.
I followed all instructions here (https://www.home-assistant.io/hassio/installation/) for the generic linux install.
To get docker-ce I added this file /etc/apt/sources.list.d/docker.list with the following inside:
deb [arch=armhf] https://download.docker.com/linux/raspbian buster nightly
deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable
Reason to also add the strech repo is that the buster repo not yet works for it self (missing packages).
But now when I try to install hass.io on my system with docker-ce I get the following error
Executing as root: curl -sL "https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh" | bash -s -- -m raspberrypi3
[Info] Install supervisor Docker container
could not get decompression stream: fork/exec /usr/bin/unpigz: no such file or directory
Any ideas how to proceed?
