I have HassIO installed on an Ubuntu 17.10 VM with Docker.
It’s been running fine for months and I haven’t changed anything recently. I am currently on .87.1 was going to upgrade. Logged onto run the configuration validator and none of my add-ons were working. They’d throw a brief error when trying to start that I couldn’t really see before it disappeared.
I rebooted the whole VM and the Hassio containers start:
root@hassio:/usr/share/hassio/homeassistant# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
5bc336d549ad hassioaddons/ide-amd64 "/init" 4 minutes ago Up 4 minutes 0.0.0.0:8321->8321/tcp addon_a0d7b954_ide
86beb5d91e2a homeassistant/amd64-addon-samba "/run.sh" 4 minutes ago Up 4 minutes addon_core_samba
31ef8f085bb2 homeassistant/amd64-hassio-supervisor "python3 -m hassio" 4 minutes ago Up 4 minutes hassio_supervisor
cfbc907f9f2a homeassistant/qemux86-64-homeassistant "/bin/entry.sh pytho…" 4 weeks ago Up 4 minutes homeassistant
But when I go to http://IPADDRESS:8123 I get a connection refused.
The home-assistant.log just shows:
2019-04-16 22:58:59 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2019-04-16 22:59:00 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=430 from 2019-04-17 02:48:26.202532)
My configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret home_zone_lat
longitude: !secret home_zone_long
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 156
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Toronto
customize: !include customize.yaml
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
http:
# Uncomment this to add a password (recommended!)
api_password: !secret http_password
# cors_allowed_origins:
# - http://hassio.area51.local:7080
#server_host: 192.168.12.11
# use_x_forwarded_for: True
ip_ban_enabled: True
login_attempts_threshold: 5
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
ignore:
- denonavr
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
recorder:
# Delete events and states older than 2 weeks
purge_interval: 5
purge_keep_days: 7
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
#sensor:
# platform: yr
ecobee:
api_key: !secret ecobee_api_key
ios:
influxdb:
host: 192.168.12.10
system_health:
lovelace:
mode: yaml
config:
device_tracker: !include device_tracker.yaml
zone: !include zones.yaml
#mqtt: !include mqtt.yaml
sensor: !include sensors.yaml
group: !include groups.yaml
#camera: !include cameras.yaml
notify: !include notifiers.yaml
input_boolean: !include inputboolean.yaml
media_player: !include media_players.yaml
zwave: !include zwave.yaml
remote: !include remotes.yaml
cover: !include covers.yaml
panel_iframe: !include panel_iframe.yaml
binary_sensor: !include binary_sensor.yaml
input_select: !include input_select.yaml
google_assistant: !include google_assistant.yaml
geofency:
It doesn’t seem to be complaining about anything in the config that it’s choking on yet I can’t get the front end.
Thanks for any help!
