[SOLVED] Having a light turn off at sunrise using run_at_sunrise complaining about arguments
So I’m really starting to get the hang of this appdaemon now (still not ready quite yet to tackle the big kahuna that I need to migrate over but I now have my kids night light app written up
boys_night_light:
  module: boys_night_light
  class: night_light_control
  lightID: light.boys_night_light
  constrain_presence: anyone
  constrain_start_time: 20:30:00
import appdaemon.appapi as appapi
import time
class night_light_control(appapi.AppDaemon):
  def initialize(self):
    self.log("Lets adjust the lights")
# Now its time for the fun stuff
    self.listen_state(self.adjust_light_function,(self.args["lightID"]))
    self.run_at_sunrise(self.sunrise_cb, 0)
# Found this cool function to convert the brightness to a percentage because well thats easier than doing math
  def brightness_to_percent(self, brightness):
    return 255/100 * int(brightness)
# Now for our function
  def adjust_light_function(self, entity, attribute, old, new, kwargs):
    self.log("Turning on the night light and setting it to 50%")
    brightness = self.brightness_to_percent(50)
    self.turn_on(self.args["lightID"], brightness=brightness)
    self.log("Now going to sleep for 2 hours")
    time.sleep(120)
    self.log("Adjusting the light to 25%")
    brightness = self.brightness_to_percent(25)
    time.sleep(120)
    self.log("Adjusting the light to 5%")
    brightness = self.brightness_to_percent(5)
  def sunrise_cb(self, kwargs):
    self.turn_off(self.args["lightID"])
However when this app initializes its complaining with this
2018-03-05 13:28:51.039357 WARNING Traceback (most recent call last):
  File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 865, in check_config
    new_config[name]["module"], new_config[name]
  File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 595, in init_object
    conf.objects[name]["object"].initialize()
  File "/config/hadaemon/apps/boys_night_light.py", line 13, in initialize
TypeError: run_at_sunrise() takes 2 positional arguments but 3 were given
2018-03-05 13:28:51.040291 WARNING ------------------------------------------------------------
I’m confused about why its getting 3 arguments passed into it when all I have defined is just the 2.
I followed the example from https://home-assistant.io/docs/ecosystem/appdaemon/tutorial/ where they go over using the run_at_sunrise and run_at_sunset. I don’t want an offset for this so thats why I just left it at 0 but I can’t see why it would think that its getting 3 arguments passed into it. I don’t see anything standing out that says hey I’m the 3rd thing you need to remove.
There is an error in that tutorial, from the current docs:
http://appdaemon.readthedocs.io/en/latest/APIREFERENCE.html?highlight=run_at_sunrise#run-at-sunrise
Try:
self.run_at_sunrise(self.sunrise_cb, offset=0)
Or just:
self.run_at_sunrise(self.sunrise_cb)
I’ll fix that tutorial.
Thank you very much for @aimc for the lightning response. Making that correction now. Lol I’m going over every line and I just couldn’t figure it out lol.
