Hi, I recently migrated from HA to HASS.IO because I wanted and container-based solution and wanted to benefit from HASS.IO add-on system.
I installed it on a Cubox-i4pro SBC using the install script and supplying the “armhf” architecture during install.
HA is working great, I can see the HASS.IO tabs but in the add-on store, I cannot install any add-on!
They all show the error: “This addon is not available on your system.”
I have not seen anything relevant in the log that would explain this situation. I see that there are add-on containers for armhf arch on DockerHub so some of them should be able to install I figure.
I’m not an expert with docker(yet) but I have the AppArmor and Supervisor containers running. Is there something I’m missing?
Personally, I’m not in love with these docker app, they seems to exists only for those people that where not able to configure a system, order to provide them a ready configured service, but at the same time, you’re without your familiar tools.
Anyway, by looking with
sudo docker logs hassio_supervisor
some log lines keeps my attention …
18-12-08 18:17:36 ERROR (MainThread) [hassio.addons.addon] Add-on core_cec_scan not supported on None with armhf architecture
I think that this “None” means something not specified during installation, something that sould be a type or something else that is not matched and result in our “not available for your system”
I’ll keep trying …
Yeah I’ve checked and I have the same error in the log file.
Looks like arch is not properly parsed. Cubox-i is armv7l which shouldn’t be an issue.
Thing is probably an env variable isn’t correctly set. that “None” should probably be set to “armv7l” or something.
EDIT: Looks like it requires the label “io.hass.machine” to be set in the supervisor container. I don’t know how to manually add that label in the container settings. I will try to reinstall using either “raspberrypi2” or “raspberrypi3” as the specified machine type in the hassio_install script.
Most likely “raspberrypi2” as it’s true armv7l and rpi3 installation might move to support full armv8l, which the cubox-i isn’t. I’m just worry about rpi2 support being not as good as rpi3 stuff for HASS.io.
So I’ve fixed the issue. Turns out you need to specify a machine type when installing in order to pull a Hassio container that is specific for a Single Board Computer.
In my case, I elected raspberrypi2 as my machine type as my Cubox-i’s ARM Arch matches best that board.
Instead of reinstalling, I just deleted the generic “armhf” images and container and pulled the “raspberrypi2” ones. “io.hass.machine” label is now properly populated when inspecting Hassio docker container. I wanted to use raspberrypi3 as my machine type but I’m worried this subset of container might get updated to run on 64-bit native targets down the line, which the Cubox-i isn’t…
So to wrap it up, in order to have support for installing Add-Ons in Hass.io, you need to make sure that the Label “io.hass.machine” is present and has a value that is supported when inspecting the hassio-supervisor container. If there’s something wrong with that label, delete all containers and images related to hassio and pull some of a Single Board Computer that best match your current target. Adjust systemd units, hassio config in /etc and maybe stuff in your hassio config folder (/usr/share/hassio).
