(solved) Help getting a value from negative to positive in template (*-1)
Hey,
I hope this is a super, super quick question. I have a modbus variable/readout that contains the current Power Grid Usage, in near-realtime. Sensor is sensor.e3dc_grid_power. This is…
a) Zero if total equilibrium is reached (this like, never happens).
b) positive number if I am TAKING power FROM the grid INTO my house or
c) negative number if I am PUTTING power FROM my HOUSE into the GRID.
For the energy dashboard I need two different sensors, one for “grid in” and the other “grid out”. So I created two new sensors:
  - sensor:
      - name: "Grid Power In"
        unit_of_measurement: "W"
        state_class: measurement
        device_class: power
        state: >
          {% if states('sensor.e3dc_grid_power') | float(0) >= 0 %}
            {% set gridin = states('sensor.e3dc_grid_power') | float(0) %}
          {% else %}
            {% set gridin = 0 %}
          {% endif %}
          {{ gridin }}
        attributes:
          last_reset: '1970-01-01T00:00:00+00:00'
This works; I get 0 if the reading is below zero, else the readout of the variable. For the opposite direction I have this:
  - sensor:
      - name: "Grid Power Out"
        device_class: power
        state: >
          {% if states('sensor.e3dc_grid_power') | float(0) =< 0 %}
            {% set gridout = (states('sensor.e3dc_grid_power') *-1) %}
          {% else %}
            {% set gridout = 0 %}
          {% endif %}
          {{ gridout }}
        attributes:
This… Does not work. If the reading is positive, zero is returned. But I need a positive reading so I wanted to add a “*-1”, so the negative value is converted to the positive value. Yields… nothing, tho. What am I doing wrong here?
After I got both sensors up, I can use the Riemann Sum Integral to get that into the Dashboard. Which already works in one direction. I am just missing the other way :slight_smile:
Thanks!
Here’s from one of my template sensors:
{{ (states('input_number.6900_upstairs_hvac_on_threshold') | float)*-1 }}
Would test in the /developer-tools/template section to confirm intended behavior.
I use a minus at the front, this changes a negative number to positive or a positive number to negative:
{% set gridout = -states('sensor.e3dc_grid_power') %}
just use absolute pipe
|abs
just tested this in the dev tools and it works fine (returns -2)
{% set gridout = (2 *-1) %}
{{ gridout }}
there must be some other issue.
or use | abs as suggested.
Any hints in the log?
Did you try with the float cast? Usually states() returns a string and strings don’t like math operations.
 {% set gridout = (states('sensor.e3dc_grid_power') | float | abs) %}
Yep, probably it. I completely missed that.
Hey,
thanks for all your replies – the issue is solved. I tried several approaches, all valid. The only faulty one way my code. Thanks!
Finally, what was the template code of your 2 sensor?
Necromancy!
But I am using the edited post above:
  - sensor:
        device_class: power
        state: >
          {% else %}
          {% endif %}
          {{ gridin }}
        attributes:
Could you please send the whole config for the 2 sensors.
I have tried to realize the “Grid out” sensor
  - sensor:
      name: "Varta Grid Power In"
      device_class: power
      state: >
        {% if states('sensor.mb_varta_grid_power') | float(0) >= 0 %}
          {% set gridin = states('sensor.mb_varta_grid_power') | float(0) %}
        {% else %}
        {% endif %}
        {{ gridin }}
      attributes:
  - sensor:
      name: "Varta Grid Power Out"
      device_class: power
      state: >
        {% if states('sensor.mb_varta_grid_power') | float(0) =< 0 %}
          {% set gridout = (states('sensor.mb_varta_grid_power') | float(0) | abs) %}
        {% else %}
        {% endif %}
        {{ gridout }}
      attributes:
However there is an error:
Invalid config for 'template' at configuration.yaml, line 313: invalid template (TemplateSyntaxError: expected token 'end of statement block', got '=') for dictionary value 'sensor->0->state', got "{% if states('sensor.mb_varta_grid_power') | float(0) =< 0 %}\n {% set gridout = (states('sensor.mb_varta_grid_power') | float | abs) %}\n{% else %}\n {% set gridout = 0 %}\n{% endif %} {{ gridout }}\n"
Your error is the use of =< which should be <=. I’d just use:
state: >
  {{ min(0, states('sensor.mb_varta_grid_power')|float(0))|abs }}
Finds the minimum of zero and your sensor, then returns the absolute (positive) value of that. For the grid-in, use
state: >
  {{ max(0, states('sensor.mb_varta_grid_power')|float(0)) }}
That has been the point, thank you so much!
I will try your short version too but this works for me:
  - sensor:
      device_class: power
      state: >
          {% set gridout = states('sensor.mb_varta_grid_power') | float(0) %}
        {% else %}
        {% endif %}
        {{ gridout }}
      attributes:
  - sensor:
      device_class: power
      state: >
        {% if states('sensor.mb_varta_grid_power') | float(0) <= 0 %}
          {% set gridin = states('sensor.mb_varta_grid_power') | float | abs %}
        {% else %}
        {% endif %}
        {{ gridin }}
      attributes:
This works very good too:
  - sensor:
      device_class: power
      state: >
      attributes:
  - sensor:
      device_class: power
      state: >
      attributes:
