I’m using Homeassistant on a Raspberry pi 4 and I want to watch it on the front side RPI monitor on the corresponding card. But rasperbery pi data doesn’t show as input, can you help?
Maybe describe in detail what you want to achieve.
My assumption is, that you want to use the HDMI port and connect it to a monitor or tv. But the way you described its not clear what you precisely want…
Sorun çözüldü.
