Solved - Help Needed
I had this working prior to an upgrade a couple weeks back. I’m on 86.1
Here is the error I get when i run Check Config,
Invalid config for [automation]: [data] is an invalid option for [automation]. Check: automation->action->0->data. (See /home/homeassistant/.homeassistant/configuration.yaml, line 114). Please check the docs at https://home-assistant.io/components/automation/
Invalid config for [automation]: expected dict for dictionary value @ data[‘action’][0][‘data’]. Got None
extra keys not allowed @ data[‘action’][0][‘volume’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 114). Please check the docs at https://home-assistant.io/components/automation/
Here is my automation, I’ve messed around with this so much it may not represent the original working automation. I may have added errors.
- id: '1548877511011'
  alias: Morning Greeting
  initial_state: true         #added this from a message I found here, made no difference.
  - entity_id: light.motion_detector
    platform: state
    to: 'on'
  condition:
  - condition: state
    entity_id: device_tracker.clay
    state: home
  - after: '8:00'
    before: '12:00'
    condition: time
  - service: media_player.volume_set
    entity_id: media_player.all_speakers
    volume: '5'
  - service: tts.google_say
    message: good morning clay,  have a great day
  - service: automation.turn_off
    entity_id: automation.morning_greeting
  - delay: '3:30'
  - service: automation.turn_on
Thanks for help and support.
Clay
You need to indent the items under data:
      volume: '5'
  - delay: '3:30'
Actually, for service calls, entity_id does not need to be placed under data; it can be at the same level as service. So this will also work:
      volume: '5'
  - delay: '3:30'
Thanks for the reply! Well neither version passed check config, but it’s better! Here’s the remaining error:
I found this one, it was in another automation, weird thing is I didn’t change it!
Thanks for the help!!
Can any one tell me how can I change it to say the current time !!
Do you mean like this?
    data_template:
      message: "{{ now().strftime('%H:%M:%S') }}"
Sorry my bad I should have asked more clearly.
What I mean to ask was, How can I make a script in hassio “Script Editor” to say current time.
in script editor it’s not taking “data_template”
I don’t use any of the GUI editors. But you’d do it the same way as a step in a script. (Actually, the action part of an automation is really just a script.)
