[solved]Help preparing Home Assistant
I’m new with Raspberry and Home Assistant. therefore please forgive me if you thing my questions are stupid.
I have a :
Rapsberry Pi 3 32 bit
32 Go micro SD card
Ethernet connected to Pi
Monitor and keyboard connected to Pi
I flashed the SD card with Balena Etcher, plugged it into Pi. Wait some times and then I have the screen attached
Then on my laptop I type 192.168.1.109:8123 in Firefox. The Preparing Home Assistant runs for hours and nothing else. I tried several times. No progress.
When loocking at the log it seems it’s turning in cycle. Below a sample of the log
22-09-11 14:58:58 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-homeassistant with tag 2022.9.1.
22-09-11 15:12:33 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.9.1: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.9.1/json: Not Found ("no such image: ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.9.1: No such image: ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.9.1")
22-09-11 15:12:33 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-09-11 15:13:03 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.9.1
22-09-11 15:13:03 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-homeassistant with tag 2022.9.1.
I have the full log availble.
I would really appreciate if someone may help me :grinning:
I would try flashing the SD card again. If this fails then try a different SD card.
I tried several times to flash the card.
It is a brand new 32 Go certified A1 card cost me 10€…
I expect not to change it
Faulty SD :upside_down_face:
I replaced it, it works :wink:
