[SOLVED] - Home Assistant not accessible from outside LAN with SWAG container for reverse proxy
I’m trying to setup SWAG container for reverse proxy in order to access Home Assistant from outside my LAN, but obviously I’m doing something wrong.
I have a Raspberry 4 with 4GB of memory. I run Docker with Portainer with the following containers:
Container Image Network IP
homeassistant home-assistant/raspberrypi4-homeassistant:stable host -
mqtt eclipse-mosquitto bridge 172.17.0.5
portainer portainer/portainer-ce:latest bridge 172.17.0.4
swag linuxserver/swag:latest bridge 172.17.0.3
zigbee2mqtt koenkk/zigbee2mqtt:latest bridge 172.17.0.2
I run SWAG container as follows:
docker run -d \
  --name swag \
  --cap-add=NET_ADMIN \
  -e PGID=1000 \
  -e PUID=1000 \
  -e [email protected] \
  -e URL=MyDomain.duckdns.org \
  -e SUBDOMAINS=wildcard \
  -e VALIDATION=duckdns \
  -e DUCKDNSTOKEN= XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX \
  -p 443:443 \
  -e TZ=Europe/Athens \
  -v /home/pi/docker/swag/config:/config \
  --restart=unless-stopped \
I have changed 3 files as follows:
  1. config/nginx/site-confs/default.conf
## Version 2022/10/03 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/nginx/site-confs/default.conf.sample
# redirect all traffic to https
server {
    listen 80 default_server;
    listen [::]:80 default_server;
    location / {
        return 301 https://$host$request_uri;
# main server block
server {
    listen 443 ssl http2 default_server;
    listen [::]:443 ssl http2 default_server;
    server_name MyDomain.duckdns.org;
    root /config/www;
    index index.html index.htm index.php;
    # enable subfolder method reverse proxy confs
    include /config/nginx/proxy-confs/*.subfolder.conf;
    # enable for ldap auth (requires ldap-location.conf in the location block)
    #include /config/nginx/ldap-server.conf;
    # enable for Authelia (requires authelia-location.conf in the location block)
    #include /config/nginx/authelia-server.conf;
    location / {
        # enable for basic auth
        #auth_basic "Restricted";
        #auth_basic_user_file /config/nginx/.htpasswd;
        # enable for ldap auth (requires ldap-server.conf in the server block)
        #include /config/nginx/ldap-location.conf;
        # enable for Authelia (requires authelia-server.conf in the server block)
        #include /config/nginx/authelia-location.conf;
        try_files $uri $uri/ /index.html /index.php$is_args$args =404;
    location ~ ^(.+\.php)(.*)$ {
        fastcgi_split_path_info ^(.+\.php)(.*)$;
        fastcgi_pass 127.0.0.1:9000;
        fastcgi_index index.php;
        include /etc/nginx/fastcgi_params;
    # deny access to .htaccess/.htpasswd files
    location ~ /\.ht {
        deny all;
# enable subdomain method reverse proxy confs
include /config/nginx/proxy-confs/*.subdomain.conf;
# enable proxy cache for auth
proxy_cache_path cache/ keys_zone=auth_cache:10m;
  1. config/nginx/proxy-confs/homeassistant.subdomain.conf
## Version 2022/09/08
# make sure that your dns has a cname set for homeassistant and that your homeassistant container is not using a base url
# As of homeassistant 2021.7.0, it is now required to define the network range your proxy resides in, this is done in Homeassitants configuration.yaml
# https://www.home-assistant.io/integrations/http/#trusted_proxies
# Example below uses the default dockernetwork ranges, you may need to update this if you dont use defaults.
# http:
#   use_x_forwarded_for: true
#   trusted_proxies:
#     - 172.16.0.0/12
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name homeassistant.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    location / {
        # enable the next two lines for http auth
        include /config/nginx/proxy.conf;
        include /config/nginx/resolver.conf;
        #set $upstream_app homeassistant;
        set $upstream_app 192.168.1.8;
        set $upstream_port 8123;
        set $upstream_proto http;
        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
    location ~ ^/(api|local|media)/ {
  1. config/dns-conf/duckdns.ini
# Instructions: https://github.com/infinityofspace/certbot_dns_duckdns#credentials-file-or-cli-parameters
# Replace with your API token from your duckdns account.
dns_duckdns_token= XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Moreover, in Home Assistant configuration.yaml I have inserted:
http:
  trusted_proxies:
    - 192.168.1.0/24
    - 172.17.0.0/24
  ip_ban_enabled: true
  login_attempts_threshold: 3
duckdns:
  domain: MyDomain.duckdns.org
  access_token: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
homeassistant:
  internal_url: "http://192.168.1.8:8123"
  external_url: "https://homeassistant.MyDomain.duckdns.org"
For the time being, I only want to use Home Assistant subdomain, but in the future I want to access more containers.
The DuckDNS IP has been configured to re-new from inside the router, so this is ok. Also, I forward TCP port 443 to Raspberry Pi.
NOTE: Since for new users is allowed only 2 links, let there MySite=https://homeassistant.MyDomain.duckdns.org
Additionaly, in Raspberry Pi I run PiHole and PiVPN (with NoIP), none of them in docker.
I have also inserted the DuckDNS address (MySite) in Home Assistant Settings / System / Network / Internet (both in PC and mobile).
When I access the address MySite from within LAN, it’s successful and it’s asking for username / password.
When I access the address MySite from outside my LAN, it’s not successful and it only shows the following:
What am I missing here???
Any help will be highly appreciated.
UPDATE: after clearing cache, the error message is “ERR_TIMED_OUT”
Finally, my ISP was blocking several ports.
After having them opened, everything was running smoothly.
Hey @JohnPlou
Does the above configuration still work for you? What version is your swag docker image ?
