I’m new to home automation and have just set up Home assistant as a container on an Intel NUC. The home assistant instance is working great locally and I can control the devices I have added without issue.
My current project is to get access externally from my network by using a reverse proxy and I have setup caddy for this purpose.
All the port forwarding for 80, 443, and the caddy side appears to be functional as I have no problem using https://portainer.mydomain.com/
to access my portainer container from outside my network.
I am having difficulty however getting Home Assistant to work.
My caddyfile contains:
`portainer.mydomain.com` { reverse_proxy 192.168.1.156:9000 } `hass.mydomain.com` { reverse_proxy 192.168.1.156:8123 }
I have added internal and external URLs:
External: https://hass.mydomain.com/
Internal: http://192.168.1.156:8123
Configuration.yaml http section is:
http: base_url: https://hass.mydomain.com use_x_forwarded_for: true trusted_proxies: - 127.0.0.1
I am making the assumption that because accessing portainer is working that the issue is not with caddy and I am failing to ensure that home assistant is correctly setup.
Much appreciation in advance for any insights you may have into fixing my situation.
