trying to install Home Assistant Supervised.
homeassistant container crashed every time after start. there is a logs.
root@HA2:/home/vic# docker logs homeassistant
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 188, in main
from . import config, runner
File "/usr/src/homeassistant/homeassistant/runner.py", line 18, in <module>
from . import bootstrap
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 27, in <module>
from . import (
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 30, in <module>
from .components import persistent_notification
File "/usr/src/homeassistant/homeassistant/components/persistent_notification/__init__.py", line 14, in <module>
from homeassistant.components import websocket_api
File "/usr/src/homeassistant/homeassistant/components/websocket_api/__init__.py", line 14, in <module>
from . import commands, connection, const, decorators, http, messages # noqa: F401
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 15, in <module>
from homeassistant.components.http import KEY_HASS, HomeAssistantView
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 44, in <module>
from homeassistant.helpers.network import NoURLAvailableError, get_url
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 9, in <module>
from hass_nabucasa import remote
File "/usr/local/lib/python3.12/site-packages/hass_nabucasa/__init__.py", line 18, in <module>
from .auth import CloudError, CognitoAuth
File "/usr/local/lib/python3.12/site-packages/hass_nabucasa/auth.py", line 12, in <module>
import boto3
File "/usr/local/lib/python3.12/site-packages/boto3/__init__.py", line 17, in <module>
from boto3.session import Session
File "/usr/local/lib/python3.12/site-packages/boto3/session.py", line 17, in <module>
import botocore.session
File "/usr/local/lib/python3.12/site-packages/botocore/session.py", line 26, in <module>
import botocore.client
File "/usr/local/lib/python3.12/site-packages/botocore/client.py", line 15, in <module>
from botocore import waiter, xform_name
File "/usr/local/lib/python3.12/site-packages/botocore/waiter.py", line 18, in <module>
from botocore.docs.docstring import WaiterDocstring
File "/usr/local/lib/python3.12/site-packages/botocore/docs/__init__.py", line 15, in <module>
from botocore.docs.service import ServiceDocumenter
File "/usr/local/lib/python3.12/site-packages/botocore/docs/service.py", line 13, in <module>
from botocore.docs.bcdoc.restdoc import DocumentStructure
File "/usr/local/lib/python3.12/site-packages/botocore/docs/bcdoc/restdoc.py", line 17, in <module>
from botocore.compat import OrderedDict
File "/usr/local/lib/python3.12/site-packages/botocore/compat.py", line 32, in <module>
from urllib3 import exceptions
File "/usr/local/lib/python3.12/site-packages/urllib3/__init__.py", line 13, in <module>
from .connectionpool import HTTPConnectionPool, HTTPSConnectionPool, connection_from_url
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 41, in <module>
from .response import HTTPResponse
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 163, in <module>
class HTTPResponse(io.IOBase):
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 396, in HTTPResponse
DECODER_ERROR_CLASSES += (brotli.error,)
AttributeError: module 'brotli' has no attribute 'error'
[10:44:18] INFO: Home Assistant Core finish process exit code 1
[10:44:18] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
please advise, where I need to look next.
may be I something missed in supervisor logs?
root@HA2:/home/vic# docker logs hassio_supervisor
cont-init: info: running /etc/cont-init.d/udev.sh
[10:43:54] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[10:43:54] INFO: Starting local supervisor watchdog...
2024-06-06 10:43:56.309 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-06-06 10:43:56.406 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64
2024-06-06 10:43:56.420 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.06.0
2024-06-06 10:43:56.420 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-06-06 10:43:56.616 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-06-06 10:43:56.619 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-06 10:43:56.621 INFO (MainThread) [__main__] Setting up Supervisor
2024-06-06 10:43:56.772 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-06-06 10:43:56.903 CRITICAL (MainThread) [supervisor.hardware.monitor] Not privileged to run udev monitor!
2024-06-06 10:43:56.906 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-06-06 10:43:56.907 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-06-06 10:43:56.909 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-06-06 10:43:56.910 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-06-06 10:43:56.912 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-06-06 10:43:56.913 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-06-06 10:43:56.914 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-06-06 10:43:56.915 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-06-06 10:43:56.916 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-06-06 10:43:56.952 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
2024-06-06 10:43:56.993 WARNING (MainThread) [supervisor.dbus.agent] No OS-Agent support on the host. Some Host functions have been disabled.
2024-06-06 13:43:57.178 INFO (MainThread) [supervisor.host.services] Updating service information
2024-06-06 13:43:57.186 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-06-06 13:43:57.191 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2024-06-06 13:43:57.373 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-06-06 13:43:57.465 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-06-06 13:43:57.495 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-06-06 13:43:57.496 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-06-06 13:43:57.663 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2024.05.0'>]
2024-06-06 13:43:57.679 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.05.0
2024-06-06 13:43:57.699 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2024-06-06 13:43:58.304 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.05.0 - 172.30.32.5
2024-06-06 13:43:58.340 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2024.04.0'>]
2024-06-06 13:43:58.353 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0
2024-06-06 13:43:58.374 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2024-06-06 13:43:58.951 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3
2024-06-06 13:43:58.953 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-06-06 13:43:58.979 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
2024-06-06 13:43:58.992 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
2024-06-06 13:43:59.008 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2024-06-06 13:43:59.688 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
2024-06-06 13:43:59.711 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
2024-06-06 13:43:59.723 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
2024-06-06 13:43:59.749 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
2024-06-06 13:44:00.452 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
2024-06-06 13:44:00.471 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
2024-06-06 13:44:00.482 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
2024-06-06 13:44:00.497 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2024-06-06 13:44:00.785 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
2024-06-06 13:44:00.791 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2024-06-06 13:44:00.829 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/qemux86-64-homeassistant versions: [<AwesomeVersion CalVer '2024.6.0'>, <AwesomeVersion CalVer '2024.5.5'>]
2024-06-06 13:44:00.851 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.6.0
2024-06-06 13:44:00.866 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
2024-06-06 13:44:00.877 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
2024-06-06 13:44:00.880 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
2024-06-06 13:44:00.897 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
2024-06-06 13:44:03.525 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
2024-06-06 13:44:03.583 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2024-06-06 13:44:03.629 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2024-06-06 13:44:03.630 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2024-06-06 13:44:03.630 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-06-06 13:44:03.630 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-06-06 13:44:03.630 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-06-06 13:44:03.630 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2024-06-06 13:44:03.630 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2024-06-06 13:44:03.631 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-06-06 13:44:03.631 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-06-06 13:44:03.631 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-06-06 13:44:03.631 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-06 13:44:03.635 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - privileged
2024-06-06 13:44:03.636 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-06-06 13:44:03.637 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-06 13:44:03.638 INFO (MainThread) [__main__] Running Supervisor
2024-06-06 13:44:03.641 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
2024-06-06 13:44:03.642 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
2024-06-06 13:44:03.642 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-06-06 13:44:03.688 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2024-06-06 13:44:03.689 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2024-06-06 13:44:03.696 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2024-06-06 13:44:03.714 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-06-06 13:44:04.201 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.6.0
2024-06-06 13:44:04.202 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-06-06 13:44:14.228 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
2024-06-06 13:44:14.229 ERROR (MainThread) [supervisor.core] Can't start Home Assistant Core - rebuiling
2024-06-06 13:44:14.245 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning homeassistant application
2024-06-06 13:44:14.416 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-06-06 13:44:14.730 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.6.0
2024-06-06 13:44:14.731 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-06-06 13:44:24.759 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
2024-06-06 13:44:24.761 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - core / None
2024-06-06 13:44:24.761 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - core / None
2024-06-06 13:44:24.762 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2024-06-06 13:44:24.800 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-06-06 13:44:24.803 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-06-06 13:44:24.810 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-06-06 13:44:24.813 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-06-06 13:44:24.814 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-06-06 13:44:24.841 INFO (MainThread) [supervisor.jobs] 'OSManager.reload' blocked from execution, no Home Assistant OS available
2024-06-06 13:44:24.841 INFO (MainThread) [supervisor.host.services] Updating service information
2024-06-06 13:44:24.852 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-06-06 13:44:24.858 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-06-06 13:44:24.911 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-06-06 13:44:24.911 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-06-06 13:44:24.912 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-06-06 13:44:24.912 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-06-06 13:44:24.912 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-06-06 13:44:24.913 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-06-06 13:44:24.913 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-06-06 13:44:24.914 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-06-06 13:44:24.916 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-06-06 13:44:24.916 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-06-06 13:44:24.927 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-06-06 13:44:24.929 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-06-06 13:44:24.929 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-06-06 13:44:25.160 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-06-06 13:44:25.196 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-06-06 13:44:25.239 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-06-06 13:44:25.240 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - privileged
