I set up a CCU3 and “integrated” it via configuration.yaml. On the Homematic WebUI I have 2 devices: a HMIP-STHO thermometer (2 channels: Temperature and Humidity) and a HMIP-PSM switch-plug (5 channels where only 2 are interesting: switch and energy Counter).
My mission is: show Temperature, Humidity and Switch, Energy Counter in HomeKit.
The setup was easy. In HomeKit appears the switch-plug - but only with the switch channel. The rest of channels and thermometer are not appearing.
In Homeassistent itself all channels are appearing correct. So I think all the data from the devices are available but not sent to HomeKit.
Where could be the mistake?
Do I need to transform the data of the channels into a new entity?
My next step is to add smoke sensors (HMIP-SWSD) and Window Contacts (HMIP-SWDO-I) an to show the states in HomeKit as well. I think it is similar to the other devices.
Thanks for your help.
