We have some devices that are manually shut off and therefore appear in the UI like this
How can I avoid that or change the behaviour to a less intrusive one ?
Thx
Thx
There is a feature that is called “hide_if_unavailable: true”,
but that one does not really work or only under very specific circumstances.
Here is a different way that works, but only for just 1 entity at a time.
So in case of such lights it will need a horizontal / vertical stack I have had already before.
One caveat in case of such lights: the single symbol of such row will be scaled up and therefore the whole becomes a higher. Here is the solution before and after in 1 picture
There is a kind of workaround or improvement in case you have 2 rows of 3 switches above each other cause the upscale factor and the height gain will be much less if you simply put not 2 in 1 row but 1 in each cause then 2 icons will be increased each by 50% instead of 1 over 200%.
That being said it is time for the code, right ?
not yet cause first you need to know that I had put the horizontal stack with the 3 bulbs in a vertical one cause these three are just a part of a bigger set of switches of each room.
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: light
entity: light.xiaomi_gateway_light
icon: 'mdi:lightbulb-on-outline'
- type: conditional
conditions:
- entity: light.wandleuchte_buro
state_not: 'unavailable'
card:
type: light
- type: conditional
conditions:
card:
type: light
entity: light.wandleuchte_couch
Key is this line: state_not: ‘unavailable’
If an entity is in any other state than ‘unavailable’ the icon / entity will be shown, otherwise it will be hidden. If all 3 are unavailable there will be nothing.
Here you find additional infos worth to read.
I hope this will help all those that will search the same way I had in my mind "how to get rid of the these ugly “missing entity messages” … which had been solveable a lot easier by a search for how to hide an entity that is not yet available, but maybe soon.
The update till a bulb or light becomes available again in the screen takes about 20 seconds and also 20 seconds if you pull the plug. It is not an instant update, just takes a few seconds longer - at least here runing HA core on a Pi-4 2GB in docker
