Solved - How to change the preferred network on my android phone
In case anyone else runs into this it was caused by the Google Play Services app. I had to force quit it and then clear the cache and data and then restart it. That corrected the Eero thing. But then the Matter server was showing as unavailable when I tried to add a device so I had to uninstall the Google Home app and reinstall it which fixed that issue. Everything is now working perfectly.
NOTE: If you clear the it will disconnect your watch if you have one and also remove all your credit cards from your google wallet. You just need the security code for each one to add them back in.
