[SOLVED]: How to create a sensor that activates when no motion sensor has been activated in the last hour
Dear all,
I have 3 xiaomi motion sensors with a group:
sensores_movimiento:
name: Sensores Movimiento
entities:
- binary_sensor.motion_sensor
- binary_sensor.presence_20
- binary_sensor.presence_21
I want to create a sensor that activates when no motion sensor has been activated in the last hour.
How I can create this sensor?, with a template?, and how I can define this templae?.
Thanks in advance,
binary_sensor:
    sensors:
      no_movement_for_1hr:
        friendly_name: "No Movement for One Hour"
        device_class: movement
        value_template: >-
          {{ ( as_timestamp( now() ) - as_timestamp( states.group.sensores_movimiento.last_changed ) ) > 3600  }}
Or
binary_sensor:
    sensors:
        device_class: motion
        delay_on:
          minutes: 60
        value_template: >
          {{ is_state('group.sensores.movimiento', 'off') }}
I find this easier to understand.
And movement is not a valid device class as far as I can see here.
Yeah that should have been motion, that’s what I get for not looking it up and going from memory.
Dear tom_l and Burningstone,
First at all thanks for your help. Any of both sollutions worked. I configured for 5 minutes (to not wait 1 houre to check) and and it has not worked. I forced the group motion sensors and wait for 6 minutes:
But the binary sensor “No movement for 1 houre” (really 5 minuts) continues with Not detected state:
It seems taht your sintax is correct, but dont works…
Jose
Drop the device class, that’s not going to work for your sensor (on = movement, when actually you want on = no movement).
Though there is something else wrong as well.
Dont works also, I configured the sensor in the binary_sensors.yaml:
  sensors:
      #device_class: motion
      delay_on:
        minutes: 1
      value_template: >
The sensor shows all the time closed estate…
Jose
Should be
And please properly format your code,asdescribe in point 11 in the community guidelines.
Dear Burningstone, thanks a lot. Now is working well.
Thanks for your help to both.
Jose
