[Solved] How to enable the Configuration menu on Lovelace
Is there an option to enable the configuration menu on Lovelace UI. I don’t have it with my setup.
top right corner, theres 3 dots, next to the bell for notifications, click the 3 dots and it should open what you want.
I was referring to the Configuration with the gear wheel on the left menu. I am trying to add new devices and need to get to the User Admin menu.
I do have the Configuration UI under the three dots. But that only changes the Lovelace tiles.
Do you have config: In your configuration.yaml file?
Thanks @silvrr. That is what I was missing.
