I’m trying to reduce the nuber of similar scripts that multiple devices of a similar type are calling from automations. My idea was to merely pass entity_id
of the target device and a state of a input_number
, as variables to the script. I have tried several options, but so far I’m ending either with errors ir odd behaviour.
UPDATE: Problem solved. Below is a working example.
The following automation is calling a script, see below.
- alias: "Extend Front Shrubs Timer When Wet"
- platform: time_pattern
minutes: '/1'
condition:
condition: or
conditions:
- condition: template
value_template: '{{as_timestamp(now().strftime("%Y-%m-%d %H:%M")) > as_timestamp(states.input_datetime.next_run_front_shrubs.state)}}'
- condition: and
conditions:
value_template: '{{as_timestamp(now().strftime("%Y-%m-%d %H:%M")) == as_timestamp(states.input_datetime.next_run_front_shrubs.state)}}'
- condition: state
entity_id: sensor.rain_sensor
state: 'too wet'
- service: script.turn_on
entity_id: script.update_generic_next_run_timer
data_template:
variables:
states_entity_timedelta_state: "{{states.sensor.time_delta_front_shrubs.state}}"
entity: "input_datetime.next_run_front_shrubs"
The script is:
update_generic_next_run_timer:
alias: "Update Generic Next Run Timer"
sequence:
- service: input_datetime.set_datetime
data_template:
entity_id: "{{entity}}"
date: >
{{(as_timestamp(now())+(states_entity_timedelta_state)|int) | timestamp_custom("%Y-%m-%d", true)}}
time: >
{{(as_timestamp(now())+(states_entity_timedelta_state)|int) | timestamp_custom("%H:%M:%S", true)}}
Currently, rather than adding 172800 seconds (as the repeat timer No square or curly brackets around the variable in the script part solved it.states.sensor.time_delta_front_shrubs.state
is set for 48hrs), the script runs but instead it keeps adding one minute to the next run time.
