Hope someone can help me out.
I have a pushbutton (binary_sensor) and a door relay (switch) which are operated through mqtt, how can I prevent them from triggering when restarting homeassistant or reloading the automations?
My configuration:
Raspberry Pi with homeassistant v0.106.6
configuration.yaml
binary_sensor:
- platform: rpi_gpio
ports:
4: Frontdoor Pushbutton
27: Backdoor Pushbutton
switch:
ports:
5: Frontdoor Lock
6: Backdoor Lock
invert_logic: true
lock:
value_template: "{{ is_state('switch.frontdoor_lock', 'off') }}"
unlock:
service: script.turn_on
entity_id: script.unlock_frontdoor
lock:
service: switch.turn_off
entity_id: switch.frontdoor_lock
value_template: "{{ is_state('switch.backdoor_lock', 'off') }}"
unlock:
entity_id: script.unlock_backdoor
lock:
entity_id: switch.backdoor_lock
mqtt_statestream:
base_topic: home-domotica
publish_attributes: true
publish_timestamps: true
include:
entities:
- binary_sensor.backdoor_pushbutton
- binary_sensor.frontdoor_pushbutton
- lock.frontdoor
- lock.backdoor
scripts.yaml
unlock_frontdoor:
alias: Frontdoor Unlock
sequence:
- service: switch.turn_on
- delay: 00:00:04
- service: switch.turn_off
unlock_backdoor:
alias: Backdoor Unlock
sequence:
- delay: 00:00:04
automations.yaml
- id: '154895186df23'
alias: Frontdoor Lock
- platform: mqtt
topic: home-domotica/lock/frontdoor/set
condition:
- condition: state
state: 'off'
- service_template: lock.{{trigger.payload}}
entity_id: lock.frontdoor
- id: '154895142df79'
alias: Backdoor Lock
- platform: mqtt
topic: home-domotica/lock/backdoor/set
condition:
- condition: state
state: 'off'
entity_id: lock.backdoor
Ubuntu VM with homeassistant v0.106.6 in venv.
configuration.yaml:
lock:
- platform: mqtt
state_topic: "home-domotica/lock/frontdoor/state"
command_topic: "home-domotica/lock/frontdoor/set"
payload_unlock: "unlock"
payload_lock: "lock"
state_locked: "locked"
state_unlocked: "unlocked"
# qos: 1
# retain: true
# optimistic: false
value_template: '{{ value }}'
- platform: mqtt
state_topic: "home-domotica/lock/backdoor/state"
command_topic: "home-domotica/lock/backdoor/set"
# qos: 1
# retain: true
# optimistic: false
Tried with retain: false and/or optimistic: true but as soon as the raspberry pi is booting or homeassistant is restarting or I reload the automations or I turn off and on the lock automation both frontdoor and backdoor locks are cycling, as in opening and closing. How can I prevent this?
Any help will be appreciated!
Regards,
Donald.
