[solved] How to trigger apps from script?
Before adopting to Appdaemon I wrote scripts, and as such they would show up in the browser for easy manual triggering by a click on the “ACTIVATE” button.
Now I would like to do the same to easily trigger my apps, can this be done?
The manual[1] talks about firing an event from script so I tried the following:
trigger_hallway_motion:
  alias: "Trigger hallway motion"
  sequence:
    - event: STATE_CHANGED
      event_data:
        entity_id: binary_sensor.aeotec_zw100_multisensor_6_sensor
        old_state: "off"
        new_state: "on"
But this does not trigger my app that uses listen_state() on the same binary_senosor…
(The app works when I physically trigger the sensor by walking in front of it.)
[1] https://home-assistant.io/docs/scripts/#fire-an-event
You can write a script that fires events and listen for them inAppDaemon directly with listen_event()
There are examples in the docs - an event is a specific thing in HASS and I don’t think you can force a state change from an automation
Here’s an example:
alias: Night
sequence:
  - event: MODE_CHANGE
    event_data:
      mode: Night
Hmmm… I was inspired by the set_state() in appdaemon. My assumption was that a script would do the same as if I had created a second app that called it like:
set_state("binary_sensor.aeotec_zw100_multisensor_6_sensor", state="on")
Would a second app work? I’m thinking a script that calls the second app with your proposed event MODE_CHANGE… (Everything to not add specific “debug code” in my first app.)
That would probably work, yes, but it’s a lot more complex than just adding a listen_event() to tour existing App :wink:
Agreed, I will probably just add the listen_event for the purpose of triggering from the browser, and try to make it possible to have a dedicated GUI element for each instance of the app.
But I will definitely try the second app approach in order to debug my apps. Thanks!
i use input_boolean to trigger apps like this:
initialize(...):
    listen_state(self.motioncallback,"sensor.motion")
    listen_state(self.motioncallback,"input_boolean.test", state="on")
motioncallback(self,...):
    motion = self.get_state("sensor.motion")
    if self.get_state("input_boolean.test") == "on":
        motion = "on"
    the appcode
    self.turn_off("input_boolean.test")
this way triggering by motion is identical with flipping a boolean on.
set_state could work also, but there are still some problems on the HA side with that.
If debugging is your goal, you can use the developer tools in the HASS UI to set the state too.
thx, never noticed that option :wink:
For now I have settled on a combination of input_boolean and template sensors/switches and running my tests and development on a separate machine. This allows me to play around without killing my production server while still using the same App code and configuration. :wink:
