[SOLVED] How to unhide hidden entities?
Hi everyone,
I am new to HA (coming from openhab) and like the steep learning curve.
However, some of my Motion sensors (or better some entities) are suddenly hidden.
I did not hide them knowingly and I don’t want them to be hidden.
So how to unhide them?
Thanks in advance!
Click on the entity and at the bottom of the pop up you will see an ‘advanced’ drop down and you can select your option.
Thanks - I tried that, but it’s deactivated (grey - not clickable)
Is there something I should overwrite (e.g. in configuration.yaml)?
EDIT:
Got it.
The entities are members of a group. In this group the member had been set to “hidden”.
I don’t remember setting them to hidden - maybe it’s the default!?
I had this issue, however the group was already deleted. Any guidance?
I had an issue where the group was deleted. What worked for me was to create a new group, include the hidden entities, enable “Hide members” and hit “submit”. Open and edit the group, disable “Hide members” and hit “submit” again. Now the entities are unhidden.
This worked for me.
