[solved] Ikea Symfonisk rotary remote as volume controller: better responsiveness
Tags: #<Tag:0x00007fc40e1d88d0>
I just started using this remote with deCONZ and it works.
One major drawback so far: it seems impossible to control the volume in small steps which is not so convenient with a mediaplayer that can be loud.
Is there anybody who has a better experience?
Bump: anyone?
It’s hard to help when you have not given us anything on how you adjust the volume with it.
Hi @Hellis81!
My first idea was to see whether anyone else who is using this remote has a better experience, since I have found similar topics.
Of course if you/someone else can help me to improve things, it’s even much better.
So I’m using a Conbee II (if that matters) with deCONZ
The automations I use (and hooks for mediaplayers): ZHA, deCONZ, Zigbee2MQTT - Ikea E1744 SYMFONISK rotary remote Universal blueprint - all actions - control lights, media players and more with Hooks
I’m not going to import a blueprint just to see the config.
But looking at some pictures in the thread it seems to use media_player.volume_up/down.
There is the problem.
Use volume_set with a template instead.
Sorry, forgot to add the code of the automation I use:
- id: '1625746328660'
  alias: Controller - IKEA E1744 SYMFONISK Rotary Remote
  description: ''
  use_blueprint:
    path: EPMatt/ikea_e1744.yaml
    input:
      integration: deCONZ
      controller_device: cc744586ed184a772321a7299bed5723
      action_rotate_left:
      - service: media_player.volume_up
          entity_id: media_player.kitchen
      action_rotate_right:
      - service: media_player.volume_down
      rotate_left_loop: false
      rotate_right_loop: false
      helper_last_controller_event: input_text.controllerrotary
      rotate_left_max_loop_repeats: 2
      rotate_right_max_loop_repeats: 2
      helper_debounce_delay: 100
      action_click_short: []
      action_click_double: []
I don’t know how to fit your suggestion into this so can you elaborate a little?
  description: ''
  use_blueprint:
    input:
      integration: deCONZ
      action_rotate_left:
      - service: media_player.volume_set
          volume_level: {{ state_attr('media_player.kitchen', 'volume_level') -0.02 }}
          volume_level: {{ state_attr('media_player.kitchen', 'volume_level') + 0.02 }}
will give you 2% higher/lower volume instead of 10%
THANK YOU: you are my hero today! :clap:
This makes the remote usable.
Had to make a small correction to the code:
      action_rotate_left:
          volume_level: '{{ state_attr("media_player.kitchen", "volume_level") -0.02 }}'
For future reference, that blueprint allows you to define the action (or actions) you want it to perform when the knob is rotated.
I can’t see the difference, but that’s good that it worked.
The template needed outer quotes.
Usually it works without. But OK…
This automation, where the 11th line’s template has no outer quotes:
Screenshot from 2021-07-30 10-38-14
won’t even pass Configuration Check:
Screenshot from 2021-07-30 10-37-30
After adding outer quotes, it passes Configuration Check.
Maybe you were thinking it doesn’t need outer quotes when the line continuation character is used?
      value: >
        {{ states('input_number.test2') }}
