I’ am new to HA and spend a lot of time in the last days to setup my basic smart home functions with Home Assistent. Not easy, but well designed and a good choice so far.
I’ve integrated some Ikea Tradfri lamps with the Ikea Integration connected to my Ikea Gateway. Works very well so far.
But i have one issue which i’am not able to solve on my own. No help on the YouTube Academy or on the blogs or here in the forum as far as i can say.
Issue:
I have two lamps which share one remote and are used as one in my setup. Regardless if i put it on or off, set the brigthness or the light temperature. The lamps are in sync. And i wan’t to preserve this in HA.
Sorry, I’m not sure I understand your question correctly. Do you want to combine the two ikea lights into one? Then you might need something like a light group: Light Group - Home Assistant (home-assistant.io)
Yes, i think you are right. In the end it is a group of twi lights. But i do not want “to see” the two lights. And moreover i want to adjust brightness and light color / light temperature for both devices together.
And i ant to have to visual as in the last part in the picture in my post.
This is what i get, when i configure one Ikea lamp in HA. And i want to have this 1:1 but with effekt to both lamps.
I’ve created a group (i think i did) and i can switch all lights from that group on and off with a switch. But i simply do not get how to adjust brightness and color temperatur together and how to hide the two “detail” lamps of that group…
Arrrghhh. Now i got it. I trapped into the Card with the Light, because it showed me my “new group” with the Name i gave it. I thougt i build a new card… i was not aware that it was an Entity based on two Entities…
