[SOLVED]/Improving Color Loop
How can I make this light do color loop/rainbow effect?
Thanks,
UPDATE WORKING CONFIG
SCRIPTS.YAML
# script.rainbow_light
rainbow_light:
  alias: rainbow light
  mode: single
  fields:
    entity:
      description: The entity that will be rainbowed
      example: light.bathroom
  variables:
    colors: |-
      {{ [[0.217,0.077], [0.157,0.05], [0.136,0.04], [0.137,0.065],
          [0.141,0.137], [0.146,0.238], [0.151,0.343], [0.157,0.457],
          [0.164,0.591], [0.17,0.703], [0.172,0.747], [0.199,0.724],
          [0.269,0.665], [0.36,0.588], [0.444,0.517], [0.527,0.447],
          [0.612,0.374], [0.677,0.319], [0.701,0.299], [0.667,0.284],
          [0.581,0.245], [0.477,0.196], [0.385,0.155], [0.301,0.116],
          [0.217,0.077]] }}
  sequence:
    - service: light.turn_on
      data_template:
        xy_color: |
          {{  colors[(now().second/2.5)|round(0)] }}
        transition: 50
        entity_id: '{{ entity }}'
AUTOMATIONS.YAML
# automation.rainbow_strip_led
alias: Living Room LEDs Rainbow Mode
description: Three LEDs Strips in Living Room
  - hours: '*'
    minutes: '*'
    platform: time_pattern
    seconds: /1
condition: []
  - service: script.rainbow_light
      entity: light.living_room_leds  # --> CHANGE THIS ENTITY TO YOUR BULB OR LED STRIP
mode: single
If it does not list an attribute like this:
effect_list: effect_colorloop
You are going to have to use a script or automation to do it.
How can I do it with script or automation, I am new to home assistant.
I getting these errors, need help
mode: single
fields:
  entity:
    description: light.living_room_leds
variables:
  colors: |-
        [0.217,0.077]] }}
sequence:
    data_template:
      xy_color: |
      transition: 1
      entity_id: light.living_room_leds
That’s a script. It needs to all be indented under script: or if you have split your configuration, put in your scripts.yaml file.
I placed them in correct locations, but am getting this error Unable to find service script.rainbow_light
chrome_XMm0mIgJaQ
Try the script like this:
rainbow_light:
  mode: single
  fields:
    entity:
  variables:
    colors: |-
          [0.217,0.077]] }}
  sequence:
      data_template:
        xy_color: |
        transition: 1
Thanks a lot, it’s working
One last thing, Is it possible make colors fade rather than hard change?
Increase the transistion time in this bit:
  sequence:
      data_template:
        xy_color: |
        transition: 1
Thanks, all good.
What are these color values [0.157,0.05] rgb?
It is xy_color.
Thanks,
Can’t thank you enough.
@anon11644107 Will the RGB values work instead of xy?
Yes you would just have to change the variables and the light.turn_on service call.
Is there a limit of how many color variables can be there?
No but there is a limit to the number of colours your lights can display. You might find that RGB values like [ 0, 248, 255] and [ 0, 255, 255] look so similar as to be indistinguishable.
Also I missed that this part of the template would need adjusting if you altered the transition time.
It would also need adjusting if you changed the number of colours. It only works with a transition time of 1 second and 25 colours. So if you have adjusted the transition time you are probably not seeing all the colours.
So 2.5 = 25 colors?
Including zero, yes.
The index for the list of colours starts counting at 0, so [0, 1, 2, 3 … 24]
60 sec / 2.5 = 24
As the transition cant be interrupted, if you use a transition time of 5 seconds you would only see 5 colours.
What transition time are you using?
Let’s say I want to use 100 colors, what would my setting for seconds and transition?
