delete
June 11, 2018, 8:23pm
1
Hi there. I’m “new” to hassio coming from vera.
Really enjoying it and so far my setup is good.
Hopefully someone can help me with the following. I have setup input sliders for my lights and have been struggeling to get them to update in the ui.
Finally it works, almost…with this config it is updating, but not linear with the “original” slider, it’s only showing values between 0-85
My config:
input_number:
office_light_brightness:
initial: 100
min: 0
max: 100
step: 5
icon: mdi:brightness-auto
automations:
Office Light Slider
alias: “Office Light Brightness”
hide_entity: true
platform: state
entity_id: input_number.office_light_brightness
service: light.turn_on
data_template:
entity_id: light.kontor_2
brightness: ‘{{ states.input_number.office_light_brightness.state | int * 2.55 | round(0) }}’
alias: Office Slider Get
platform: state
service: input_number.set_value
data_template:
value: ‘{{ states.light.kontor_2.attributes.brightness | float / 2.55 | round(0) }}’
I’m a little confused at what you’re trying to attempt. Are you trying to make 1 slider value equal to another?
Why are you using int * 2.55 and float?
If I get it right, you want a slider that you slide and it changes the brightness of your office lights?
+1 forsquirel; also what is ‘original’ slider?
delete
June 11, 2018, 9:06pm
5
Yes, sorry it that was alittle unclear.
I have created a slider in the ui, so i dont have to click twice on the light to access the slider, if that makes sense to you?
Now I just realized that both sliders will only go max 85?? Without the “Office Slider Get” automation they both go to 100…
delete
June 11, 2018, 9:09pm
6
Sorry guys, this a little “learning by doing” for me. Most of my stuff, I have figured out from reading and google… I guess the int * 2.55 and float comes from my wish to have a slider from 0-100…
Just use brightness_pct instead of brightness? That way 100 is 100%
delete
June 11, 2018, 9:37pm
8
Thanks man, tried with the _pct, and both sliders are working. But the slider in the frontend (which i have created) is still not updating…
hide_entity: true
platform: state
data_template:
brightness_pct: ‘{{ states.input_number.office_light_brightness.state }}’
platform: state
data_template:
value: ‘{{ states.light.kontor_2.attributes.brightness.state }}’
Yeah, I can’t get it to work with % either. But I got it working with brightness. Both sliders change, when I change one of them.
Automation:
- id: '1528751771536'
alias: Office lights
- entity_id: input_number.office_light_brightness
platform: state
condition: []
- data_template:
brightness: '{{states.input_number.office_light_brightness.state | round(0)}}'
entity_id: light.yeelight_color_ceiling_lamp_bedroom
- id: '1528753102452'
- entity_id: light.yeelight_color_ceiling_lamp_bedroom
platform: state
condition: []
- data_template:
value: '{{states.light.yeelight_color_ceiling_lamp_bedroom.attributes.brightness | round(0)}}'
Remember to change your entity id’s and values back to your own.
delete
June 12, 2018, 9:33pm
10
I twisted my head last night and finally got it working perfectly, with % and a scale on the slider showing 0-100. The trick was to create a template sensor for the brightness.
For anyone else searching for this topic i’m posting my config:
input_number:
initial: 100
min: 0
max: 100
step: 5
# Brightness Office Light
sensors:
light_office_2_brightness:
friendly_name: 'Office Brightness'
value_template: '{{ states.light.kontor_2.attributes.brightness | int / 2.55 }}'
unit_of_measurement: '%'
automations:
# Office Light Slider
- alias: "Office Light Brightness"
hide_entity: true
platform: state
- service: light.turn_on
data_template:
brightness_pct: '{{ states.input_number.office_light_brightness.state }}'
- alias: Office Slider Get
platform: state
data_template:
value: '{{ states.sensor.light_office_2_brightness.state }}'
## Packages / Kitchen Ceiling lights
# homeassistant:
# customize:
input_number:
- kitchen_light_brightness:
initial: 100
min: 0
max: 100
step: 5
# Brightness Kitchen Light
sensors:
kitchen_light_2_brightness:
friendly_name: 'Kitchen Brightness'
value_template: >-
{{ states.switch_keukenlicht.attributes.brightness | int / 2.55 }}
# Kitchen Light Slider
automations:
- alias: "Kitchen Light Brightness"
hide_entity: true
platform: state
entity_id: input_number.kitchen_light_brightness
- service: switch.turn_on
data_template:
entity_id: switch_keukenlicht
brightness_pct: '{{ states.input_number.kitchen_light_brightness.state }}'
- alias: Kitchen Light Slider Get
platform: state
- service: input_number.set_value
data_template:
value: '{{ states.sensor.kitchen_light_2_brightness.state }}'
Hi, sorry to start this post again, but I can’t get my head around it. I used ‘delete’ his/her code but my config won’t validate it. What am I missing?
petro
(Petro)
January 22, 2019, 8:41pm
12
Thats not a valid entity id in there. You’re missing the domain. I’m guessing it should be
states.light.switch_keukenlicht.attributes.brightness
homeassistant:
customize:
input_number:
initial: 100
min: 0
max: 100
step: 5
platform: template
sensors:
friendly_name: ‘Kitchen Brightness’
unit_of_measurement: ‘%’
value_template: >-
{{ state_attr(‘switch.keukenlicht’, ‘brightness’) | int / 2.55 }}
automations:
alias: “Kitchen Light Brightness”
hide_entity: true
platform: state
data_template:
entity_id: switch.keukenlicht
brightness_pct: “{{ states(‘input_number.kitchen_light_brightness’) }}”
platform: state
data_template:
value: “{{ states(‘sensor.kitchen_light_2_brightness’) }}”
Thanks Petro for the reply, changed it and some other settings, yet still not correct… What do I miss?
Sorry for the messy layout.
petro
(Petro)
January 23, 2019, 2:31pm
15
the switch domain does not have a brightness attribute, so this will never work.
{{ state_attr('switch.keukenlicht', 'brightness') | int / 2.55 }}
Thanks for the reply. Is there any way to convert a switch component into a component, like light, to use brightness?
The switch is a Shelly1, and I have a LED light connected to it. The light is dimmable so I would like to know what to make of it to get it dimmable, so the brightness component to work.
petro
(Petro)
January 23, 2019, 3:39pm
17
how is it integrated into HA? What component?
I have MQTT component active on the Shelly1 and integrated it as a switch.
petro
(Petro)
January 23, 2019, 3:45pm
19
Change it to an MQTT light.
You’ll need to add brightness to your topic or a separate topic. And you’ll need your device to interpret the topic.
Thank you!! Totally forgot that component. Thanks for adding the extra info regarding the topic.
I hope to figure this out and will let ya know the outcome.
