Hey yall, im hoping the title makes sense. What I want to do is:
- have google tts say something from a speaker. (This I can do)
- have the option to play from a drop down list of preset sayings. (I can do this as well)
- have the option to enter custom text instead. (I can’t get this to work)
I also can’t get the combination of 2 and 3 to work.
This is what I have. Not sure how to go about this really.
alias: Test
sequence:
- data_template:
entity_id:
- media_player.kitchen_display
message: "{{ states('input_select.presetwords') }}"
service: tts.google_translate_say
mode: single
icon: mdi:bullhorn
I added a screenshot showing what I want to do.
TIA for any help!
EDIT:
I realized I should have added this as well.
Do you need the custom words to show up in the list? I think that might be possible with a Template select, but I’ve never tried it.
If not, you should be able to use something like the following:
alias: Test
sequence:
- data_template:
entity_id:
message: >
{% set state = states('input_select.presetwords') %}
{{ iif( state == 'Custom Text', states('input_text.customwords'), state ) }}
mode: single
icon: mdi:bullhorn
It’s been a while since I set up something similar for Alexa… At that time there were issues with the standard Dashboard cards updating the state of the input text helper, I ended up using a modified version of the custom input text row, but that may have been fixed now.
I think I see what you did there. I’m still new to all this lol. I’ll give it a shot today and see how it works.
Its works! Thank you!
Where/ how did you learn to do that?
That way I can learn how to as well.
Mostly from posts on this forum and reading the templating documentation:
Home Assistant Templating docs
Jinja docs
And a lot of trial and error…
