I just uninstalled and reinstalled the iOS companion app to clear all settings. The I launch it now, I get the initial screen with the continue button on the bottom. I click continue and the second screen starts to load and the app immediately crashes.
I have rebooted my phone, and uninstalled and reinstalled the app.
I just tried to uninstall the app, reboot my phone and reinstall the app. Still crashed
I had the same problem. I needed to add an internal_url and an external_url in my config under the homeassistant: section. Then restart HASS so that config is reloaded. After that the app worked again.
I went into Home Assistant General Settings and added the internal and external URL. Reboot the Pi. Still didn’t work. Woke up this morning and tried it again, and it let me set up the app. I am really confused. But I’ll go with it.
I added the internal_url and external_url values in the settings, and it didn’t work for me either. Till I woke up this morning. Which really makes no sense, but I’ll go with it.
Found another solution that worked for me. Disable WiFi and reopen then app. While the next screen shows up where you can put in the URL, just reconnect to your WiFi and put in the URL and click next.
I took Home Assistant offline by restarting it, entered the URL manually and it also worked.So I guess it does have something to do with auto discovery of Home Assistant instances.
