cat /home/homeassistant/.homeassistant/home-assistant.log
2023-08-19 09:38:35.258 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2023-08-19 09:38:35.590 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2023-08-19 09:38:35.591 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2023-08-19 09:38:35.592 WARNING (MainThread) [homeassistant.setup] Setup of application_credentials is taking over 10 seconds.
2023-08-19 09:38:35.592 WARNING (MainThread) [homeassistant.setup] Setup of script is taking over 10 seconds.
2023-08-19 09:38:35.593 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2023-08-19 09:38:39.216 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform smtp
File "/usr/local/lib/python3.11/smtplib.py", line 398, in getreply
line = self.file.readline(_MAXLINE + 1)
File "/usr/local/lib/python3.11/socket.py", line 705, in readinto
return self._sock.recv_into(b)
TimeoutError: timed out
File "/srv/homeassistant/lib/python3.11/site-packages/homeassistant/components/notify/legacy.py", line 93, in async_setup_platform
notify_service = await hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/srv/homeassistant/lib/python3.11/site-packages/homeassistant/components/smtp/notify.py", line 100, in get_service
if mail_service.connection_is_valid():
File "/srv/homeassistant/lib/python3.11/site-packages/homeassistant/components/smtp/notify.py", line 162, in connection_is_valid
server = self.connect()
File "/srv/homeassistant/lib/python3.11/site-packages/homeassistant/components/smtp/notify.py", line 148, in connect
mail = smtplib.SMTP(self._server, self._port, timeout=self._timeout)
File "/usr/local/lib/python3.11/smtplib.py", line 255, in __init__
(code, msg) = self.connect(host, port)
File "/usr/local/lib/python3.11/smtplib.py", line 343, in connect
(code, msg) = self.getreply()
File "/usr/local/lib/python3.11/smtplib.py", line 401, in getreply
raise SMTPServerDisconnected("Connection unexpectedly closed: "
smtplib.SMTPServerDisconnected: Connection unexpectedly closed: timed out
Perhaps because target is not a valid email address. See docs, I think target is
recipient list | string REQUIRED
Default E-mail address of the recipient of the notification. This can be a recipient address or a list of addresses for multiple recipients.
This is where you want to send your E-mail notifications by default (when not specifying target in the service call). Any E-mail address(es) specified in the service call’s target field will override this recipient content.
2023-08-19 12:22:57.917 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform smtp
