[SOLVED] Issue with WebSocket and NGINX reverse proxy
So, installed HASSOS on x86 hardware, all works perfectly. Can connect directly (10.0.0.2:8123) and such.
Setup NGINX reverse proxy (10.0.0.1) for remote access with following config:
server {
        server_name ha.xxx.com;
        listen 443 ssl;
        http2 on;
        add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
        proxy_buffering off;
    location / {
        proxy_pass http://10.0.0.2:8123/;
        proxy_set_header Host $host;
        proxy_redirect http:// https://;
        proxy_http_version 1.1;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
And dropped this into my configuration.yaml (from file editor):
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 10.0.0.0/24
Reloaded configuration / restarted HA.
Now, accessing via proxy kinda works, but often fails. From firefox network console i can clearly see that the WebSocket fails to connect 9 times out of 10, but that random once does connect.
Any help on this? It seems that i cannot find anything meaningful in HA logs, and NGINX just complains that upstream blocked the connection.
Sometimes reloading the page helps, most of the time i only need to wait half a mitnute then the WebSocket will connect again.
Any help is appreciated?
might be some limiter / DDoS prevention in HA?
Here is a screenshot of firefox network console:
Solved: i had TWO devices with the same IP address, and one of them was indeed my HA instance.
Be careful! 4 days of heavy debugging! :slight_smile:
