I am trying to setup the IR blaster but everytime it learns a code and I try to play the code back, it doesn’t work. I can confirm in my logs that the payload is sent.
Here are the logs for debug Debug 2024-04-19 10:28:32Starting IR Code Learning...Debug 2024-04-19 10:28:32 - Pastebin.com
What I’ve tried:
- Resetting the IR blaster
- Restarting zigbee2mqtt and HA containers.
- Sending code via scripts and zigbee2mqtt UI
- Placing the blaster nearer to a/c and away.
- Hiding the blaster away from any light
- Using an old IR blaster (using tuya) to send the code.
I have verified:
- Communications between zigbee2mqtt - HA is working fine, got the name and payloads correct
I couldn’t find any publicly available IR codes for this a/c which is a mitsubishi starmex. If anyone has details and willing to share please let me know!
Update:
Honestly, no proper solution. I just kept moving my IR around, and I reinstalled the batteries. I noticed a difference, now when it sends the code, it sends as a sequence. Perhaps someone can understand this better than I do.
