Solved: LCN Lights, Scenes and Light Card
UPDATE: Never mind: It was the 50steps setting for dimming in the LCN connection settings. a dim_mode: 200steps did the trick. Maybe 200steps sould be the default setting instead of 50steps.
Markus
A HA newbie here coming from Symcon with a rather extensive LCN installation.I really like HA, but got some early stage problems regarding the LCN integration:
When a light was dimmed to specific level via a LCN light scene, let’s say 25%, then the light cards 100% position is the 25% of the light in LCN. So you can only dial between 0 and 25% but not to 100% of the LCN output.
I’ve also tried the LCN_abs via service like:
myhome.0.7
output: output1
brightness: 100
transition: 0
But it sets the output not to 100%, but to the brightness (e.g. 25%) of the active LCN light scene and does not override it.
Any suggestions?
Markus
Hi, How did you fix it?
Answer is already here.
Exactly! It was the missing 200 steps setting.
